Update to 7.0.20 Widget problems
  • dmalchikov
    • Sep 2018
    • 15
    Right after updating from version 7.0.19 (Ubuntu 22.04, PgSQL 14, PHP 8.1), I started seeing error messages on certain widgets—specifically for CPU and Memory (both Windows and Linux). There may be issues with other widgets as well, but the graphs and dashboards themselves show no errors.
    Does anyone have any idea what might be causing this or how to fix it?
  • Answer selected by dmalchikov at 30-10-2025, 11:13.
    sancho
    • Mar 2015
    • 300
    Hello, take a look at this.
    It may be the same problem even though they are different versions.
    • PSklyar
      • Sep 2025
      • 30
      Hey, hey
      I think can start with clear cache
      sudo -u zabbix php /usr/share/zabbix/bin/zabbix_cache_cleaner.php -c /etc/zabbix/zabbix.conf.php
      If problem will remain then check opportunity to create widgets or repair item keys
      • dmalchikov
        dmalchikov commented
        Thanks for suggestion! Could be good solution but there is no file zabbix_cache_cleaner.php at OS disk )))
        Even Directory /usr/share/zabbix/bin/
    • sancho
      • Mar 2015
      • 300
