net.if.out[] on 64bit systems
  • ProTON
    • Oct 2005
    • 77
    I have net.if.out[eth0] item configured as Delta (speed per second), and it always shows the same 50Gbps traffic. It was working on the 32bit system before the upgrade.
    P.S. Zabbix is recompiled after upgrade to 64bit libraries.
  • vrtareg
    • May 2006
    • 293
    Hi
    I have the same problem on 64 bit systems.
    See this thread for more details.
    Areg
    • ProTON
      • Oct 2005
      • 77
      I think I solved it -> http://www.zabbix.com/forum/showthread.php?p=17554
      • quekky
        • Nov 2004
        i had the same problem suddenly happening last night, and just managed to found the same solution this morning
        • kevinappel
          • Mar 2006
          • 21
          I am experiencing the same issue on 64 bit servers.
          How do you have the item configured, i.e. numeric float, or numeric integer 64 bit, units, multiplier, custom multiplier,store value?
          What steps did you take to have values start working? If you modified the type of a value stored in the DB, but it mess with your current values?
          • ProTON
            • Oct 2005
            • 77
            Numeric (float)
            Units: bits
            Custom multiplier by 8
            Database modification doesn't affect current values stored, because my patch only tells MySQL to use more bytes for all future values.
            • kevinappel
              • Mar 2006
              • 21
              Thanks for that info, one more question. From the patch it looks like you modify the value field inside the history table and prevorgvalue inside the items table. What SQL commands do I need to run to make this happen?
              • ProTON
                • Oct 2005
                • 77
                ALTER TABLE history MODIFY value DOUBLE(24,4) DEFAULT '0.0000' NOT NULL;
                ALTER TABLE items MODIFY prevorgvalue DOUBLE(24,4) DEFAULT NULL;
                • djinn_fr22
                  • Jan 2007
                  • 54
                  Works for me.
                  Thank you for the patch.
                  • kevinappel
                    • Mar 2006
                    • 21
                    Thanks, so far it looks like the numbers are good
                    • vrtareg
                      • May 2006
                      • 293
                      Hi
                      I use "Numeric (integer 64bit)" for the net.if.in/out items.
                      Is this not correct?
                      the data type for this items is uint.
                      Now i change data type to float and graphs corrected.
                      I also alert database.
                      Areg
                      • ProTON
                        • Oct 2005
                        • 77
                        It doesn't matter which type you use. The problem is with prevorgvalue field in items table. 64bit items simply does not have enough space to fill this MySQL field.
                        • vrtareg
                          • May 2006
                          • 293
                          Thanks for explaining situation.
                          Areg
                          • kevinappel
                            • Mar 2006
                            • 21
                            One more question, this currently reports in bits , what do I need to change to have bytes?
                            • vrtareg
                              • May 2006
                              • 293
                              #15
                              Hi
                              The net.if.in/out items return result in bytes.
                              What multiplier and units do you use?
                              I set Units to Bps and set multiplier to "Do not use" and i see my results in Bps, KBps, Mbps ....
                              Areg
