Zabbix Agent 7.4.3 and 7.4.5 not starting on Windows
  • Robert W
    • Oct 2022
    I have many servers (105) where these new agents wont start. I upgrade and start the service, the zabbix log only adds the below info, and after a while the zabbix agent stops.
    So I have to downgrade on these servrers.
    The servers are from different customers and different OS versions.
    4748:20251106:082827.023 using configuration file: C:\Program Files\Zabbix Agent\zabbix_agentd.conf
    9488:20251106:082902.499 Starting Zabbix Agent [VMDRIFT05]. Zabbix 7.4.5 (revision c525822dce0).
    9488:20251106:082902.500 **** Enabled features ****
    9488:20251106:082902.501 IPv6 support: YES
    9488:20251106:082902.501 TLS support: YES
    9488:20251106:082902.501 **************************
  • BP_Vital
    • Feb 2016
    • 49
    Try to increase DebugLevel in zabbix_agentd.conf for more details.
    • Robert W
      • Oct 2022
      I have. And it still doesn't spit out anything more information :/
      • Andrejs Poddubņaks
        • Nov 2025
        • 18
        Hi, Robert!
        It seems that you are not facing a configuration error, but a bug in the Windows version of Zabbix Agent 7.4.x.
        There is currently an open ticket in the Zabbix bug tracker — ZBX-27074: [ZBX-27074] Zabbix Agent 7.4.3 crashes during PDH initialization on Windows Server 2022 - heap corruption in zbx_get_all_counter_names() - ZABBIX SUPPORT
        The symptoms are very similar to yours:
        Agent 7.4.3/7.4.5 on Windows starts up, but the log only shows the block with “Starting Zabbix Agent / Enabled features,” after which, after a while, the process simply terminates without a clear error message. Exactly the same messages can be found in the official forum thread “Zabbix Agent 7.4.3 and 7.4.5 not starting on Windows”.​
        What you can do now:
        1. ​The safest solution right now is to stay on the agent version that worked stably for you before the update (for example, earlier 7.4.x or 7.2/7.0) until Zabbix releases a fix for this bug.
        2. Testing on a test host:
        Enable detailed logging in zabbix_agentd.conf:
        LogType=file
        LogFile=C:\zabbix_agentd.log
        LogFileSize=0
        DebugLevel=4
        3. Temporarily remove/comment out:
        PerfCounter= / PerfCounterEn=
        all Include files with custom .conf files that contain perf counters or complex UserParameters.
        ​Try running the agent with the “minimal” configuration (without TLS, without additional modules).
        4. Monitoring and waiting for confirmation
        Keep an eye on ticket status ZBX-27074 in the Zabbix bug tracker and release notes for upcoming versions 7.4.x.
        • Robert W
          • Oct 2022
          Thanks!
          Unfortunately 7.4.2 is not available on zabbix.com any longer :/
