Proxy monitoring doesn't show any data
  • mwwlodek
    • Nov 2025
    I have weird issue - right now 2 out of 4 proxy cannot show any data for assigned hosts (for now only snmp).
    Offline proxy is problem with server, but rest of proxy server are "Online".
    Some info:
    1. First and forth proxy works without any issue for now, but it is also the newest one.
    2. Default port is changed to 11050 and 11051.
    3. I can reach them from both side on 11051, 11050 is not reachable on all of them.
    4. All hosts attached to proxy 2 and 3 is not able to proceed with any data (even ping).
    5. I can reach hosts via snmpwalk/get on their system directly.
    6. I get data thorugh integrated zabbix inventory -> test -> get value and test for proxy 2 and 3.
    7. I believe for some time at the beggining it works.
    Have anybody reach the same issue?
    What more can I check?
  • PSklyar
    • Sep 2025
    • 30
    Hey, hey
    I would recommend beginning investigation from checking proxy logs
    Then check which process bound to which port:
    sudo netstat -tlnp | grep zabbix
    After that, found needed and check if proxy listening port:
    sudo netstat -tlnp | grep portnumber
    sudo ss -tlnp | grep portnumber
    sudo lsof -i : portnumber
