Error on Zabbix Installation 7.2 LTS / 7.4 -> Ubuntu 22.04 LTS
  • newcomer61
    • Dec 2025
    Hi there,
    if I use the command:
    apt install zabbix-server-mysql zabbix-frontend-php zabbix-apache-conf zabbix-sql-scripts zabbix-agent
    on each installation (30 times) on same place the following error:
    Vorbereitung zum Entpacken von .../zabbix-apache-conf_1%3a7.2.14-1+ubuntu22.04_all.deb ...
    Entpacken von zabbix-apache-conf (1:7.2.14-1+ubuntu22.04) ...
    dpkg: Fehler beim Bearbeiten des Archivs /var/cache/apt/archives/zabbix-apache-conf_1%3a7.2.14-1+ubuntu22.04_all.deb (--unpack):
    Versuch, »/usr/share/zabbix/auditacts.php« zu überschreiben, welches auch in Paket zabbix-frontend-php 1:5.0.17+dfsg-1ubuntu0.1~esm1 ist
    Fehler traten auf beim Bearbeiten von:
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    I hope you can help me...
    Regards.
  • tim.mooney
    • Dec 2012
    • 1436
    I think you may have some zabbix packages from 5.0.x that are already installed.
    You also appear to be installing the packages provided by your distro vendor, Ubuntu, rather than the official Zabbix packages.
    • newcomer61
      • Dec 2025
      That's it.
      After properly deleting all packages, I was able to successfully reinstall.
      Thank you so much!
