Graph issues in 1.1.4 with 10 items on a graph
  • kevinappel
    • Mar 2006
    • 21
    I am using 1.1.4 and have been playing around with the graphs. If I have create a graph and have 10 items on the graph, there is an error displaying the graph when the width is 1172 or wider. I have this graph as part of a screen, and when clicking on the graph with the web browser maximized, the image of the graph does not display, but the little not found icon displays instead. If I shrink the web browser to not be the entire size, so the image is only 900 pixels wide for example, the graphs displays as expected. Removing half of the items so there are only 5 items instead of 10 will let me view the graph at the normal 1172 or wider setting.
    Has anyone else experienced anything similar, or can someone else try to duplicate this in their environment?
    Thanks,
    Kevin
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    This is a common issue. Increase memory settings in php.ini.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • kevinappel
      • Mar 2006
      • 21
      Thanks, I set the memory to 16M and its working now.
