Making trigger to see if idle has been less then 5% for last 4 hours
  • kevinappel
    • Mar 2006
    • 21
    Can someone assist me with creating a trigger that will alert me if the idle % has been less than 5% for the past 4 hours?
    I know I will be using the item: system.cpu.util[,idle,] just not sure how to wrap the whole thing for the 4 hour constraint.
    Thanks,
    Kevin
  • dantheman
    • May 2006
    • 209
    To start with you'll need an item that monitors the idle percentage on the host.
    Assuming your host is called web, your trigger should look something like this..
    {web:system.cpu.util[,idle,].min(14400)}<5
    14400 is the number of seconds that the item would need to be under 5 for the trigger to fire.
    • dantheman
      • May 2006
      • 209
      http://www.zabbix.com/manual/v1.1/config_triggers.php
      This is a useful page when working with triggers to see what options you have available as well as to help with syntax, etc..
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        I believe correct trigger would be
        {web:system.cpu.util[,idle,].max(14400)}<5
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
        • kevinappel
          • Mar 2006
          • 21
          thanks a bunch
