win32 agent service won't start.
  • malcontent
    • Mar 2005
    • 15
    I have tried installing several versions of the win32 agent on my windows XP laptop and none of them will start. When I attempt to start the service it says "process terminated unexpectedly" the event logs also contain the same message. I set the debugging level to 4 and the logs don't contain any error messages, just that it's listening. Like this.
    [18-Jan-2007 16:45:42] Zabbix Win32 Agent started
    [18-Jan-2007 16:45:42] Information: 2232 : Listen thread is Started.
    [18-Jan-2007 16:45:42] Information: 5520 : Listen thread is Started.
    [18-Jan-2007 16:45:43] Information: 2332 : Listen thread is Started.
    [18-Jan-2007 16:45:43] Information: 4640 : Listen thread is Started.
    [18-Jan-2007 16:45:43] Information: 5748 : Listen thread is Started.
    [18-Jan-2007 16:45:43] Information: 5760 : Listen thread is Started.
    [18-Jan-2007 16:45:43] Information: 3532 : Listen thread is Started.
    [18-Jan-2007 16:45:43] Information: 3876 : Listen thread is Started.
    [18-Jan-2007 16:45:43] Information: 5756 : Listen thread is Started.
    [18-Jan-2007 16:45:43] Information: 5772 : Listen thread is Started.
    No hint that anything went wrong at all.
    Can anybody help me get this agent running? So far I have tried the agents from the 1.1 branch, the 1.3 branch and the installer that somebody contributed.
    BTW I can telnet into the zabbix port on the server.
  • CEGR
    • Feb 2007
    I have the same problem here!
    We are experiencing the same problem here, do you have any solution for this?
    BTW I can telnet into the zabbix port on the server.[/QUOTE]
