Suppress particular drive from space warnings
  • errorsandtheircauses
    • Jan 2026
    Hello there, i get a message such as this and i want to suppress it for only certain machines and or drives. Not sure how to achieve that.
    NPS_LOGS(L: Disk space is critically low (used > 90%)
    Again, we like that it logs these messages, but this disk already rotates its logs, so will always be mostly full. This is working as intended so i dont need an alert about it.
    any help appreciated. I thought there would be some kind of exclude button, but i cant find one. I was able to exclude a different problematic service by editing a macro on that particular "template" but i cant figure out how to do it for this event.
    • 5004
    Putting a windows service to "ignore" list makes it ignore it, its not even monitoring it any more.
    If you want to gather data, but not generate events about it, set that threshod (I hope it is set with a contextual macro), to higher value on host level... value over 100 will never trigger. You keep monitoring and graphs, but it will never trigger.
    • Manuel Deschambault
      • Jan 2026
      • 27
      What you would need is to remove only the trigger for this item, this way it is still monitored, but it does not trigger if it is not happy
      • LenR
        • Sep 2009
        • 1011
        I use a < %space AND < 500MB (or something) trigger, 10% of a large drive is a lot of space.
