Hi guys, im using zabbix 3.2 and facing some problem which at monitoring tab showing email sent but i cant receive any mail from zabbix. Anyone please help me. Thanx in advance.
Zabbix cannot send notification mail
Hi, hizamI!
Have you've configured you SMTP properly ( Administration -> Media Types- >Email) ?
If yes, is there any error messages in Report -> Action log ?
Regards,
Alex -
Dear allexpetrov,
my company using gmail service. If I put SMTP.gmail.com, action status failed to send the notification. But, if i put SMTP localhost, action status showing successfully sent to the mail that i set in media types. When i checked inbox, there has no email receive from zabbix. There are my 2 different configurations:
smtp server: localhost
smtp server port: 25
smtp helo: zabbix
smtp email: root@zabbix
connection security: none
authentication: none
ACTION STATUS: SENT (but i did't receive any mail from zabbix)
smtp server: smtp.gmail.com
smtp server port: 587
smtp helo: gmail.com
smtp email: hizami@impact multimedia.com
connection security: SSL/TLS
authentication: my email/ my password
ACTION STATUS: FAILURESComment
Are you sure the zabbix server can connect to smtp.gmail.com?Dear allexpetrov,
smtp helo: zabbix
Open a shell on the server and try to:
you should get a connect.Code:telnet smtp.gmail.com 587
Yes, you are not receiving tanything from zabbix, because there is no relay for default instance.Dear allexpetrov,
smtp helo: zabbix
Are you sure that your SMTP helo is correct ?
Also, when you hovering the error - what kind of message appears - Authentication failure or what ?
Regards,
AlexComment
