high bandwidth alerts constantly triggering
  • bloodyskullz
    • Jan 2025
    • 52
    Problem is:
    4 vm's running debian 11 and 12 reporting numbers astronomically high for interface triggering high bandwidth alerts
    values recieved for bits recieved and sent are in the realm of 1.38 Tbps and 691.55 Gbps
    Common info amongst the 4 vms:
    all connected through the same proxy
    iftop on the interface shows low numbers (KB and MB)
    agent versions are the same amongst all 4 (7.2)
    vms run on esxi 8.x
    vmxnet3 interface
    zabbix detecting correct interface speed
    Tried:
    deleting host
    changing the intervals for the item prototypes for net if
    changing the trigger completely
    Current trigger:
    problem
    avg(/P9 Linux by Zabbix agent active-Chris/net.if.in["{#IFNAME}"],15m) >
    ({$IF.UTIL.MAX:"{#IFNAME}"}/100) *
    (last(/P9 Linux by Zabbix agent active-Chris/vfs.file.contents["/sys/class/net/{#IFNAME}/speed"]) * 1000000)
    or
    avg(/P9 Linux by Zabbix agent active-Chris/net.if.out["{#IFNAME}"],15m) >
    and
    last(/P9 Linux by Zabbix agent active-Chris/vfs.file.contents["/sys/class/net/{#IFNAME}/speed"])>0
    recovery
    avg(/P9 Linux by Zabbix agent active-Chris/net.if.in["{#IFNAME}"],15m) <
    (({$IF.UTIL.MAX:"{#IFNAME}"}-10)/100) *
    and
    avg(/P9 Linux by Zabbix agent active-Chris/net.if.out["{#IFNAME}"],15m) <
    I am at a loss here. Logs show nothing and the only other thing i didn't do is remove the agent and install a later version but other vms run the same agent version and no issues.
    • 5004
    Without really digging into all of it and not having a test mule available... I would say there is somekind of issue with reported values and preprocessing... All these items have custom multipliers used... maybe your host reports values in some units that are not suitable for multiplying?
    Original trigger has no " * 1000000" in it.. it is in preprocessing for speed item.
    Problem: (avg(/Linux by Zabbix agent active/net.if.in["{#IFNAME}"],15m)>({$IF.UTIL.MAX:"{#IFNAME}"}/100)*last(/Linux by Zabbix agent active/vfs.file.contents["/sys/class/net/{#IFNAME}/speed"]) or avg(/Linux by Zabbix agent active/net.if.out["{#IFNAME}"],15m)>({$IF.UTIL.MAX:"{#IFNAME}"}/100)*last(/Linux by Zabbix agent active/vfs.file.contents["/sys/class/net/{#IFNAME}/speed"])) and last(/Linux by Zabbix agent active/vfs.file.contents["/sys/class/net/{#IFNAME}/speed"])>0
    Recovery: avg(/Linux by Zabbix agent active/net.if.in["{#IFNAME}"],15m)<(({$IF.UTIL.MAX:"{#IFNAME}"}-3)/100)*last(/Linux by Zabbix agent active/vfs.file.contents["/sys/class/net/{#IFNAME}/speed"]) and avg(/Linux by Zabbix agent active/net.if.out["{#IFNAME}"],15m)<(({$IF.UTIL.MAX:"{#IFNAME}"}-3)/100)*last(/Linux by Zabbix agent active/vfs.file.contents["/sys/class/net/{#IFNAME}/speed"])
    If you say speed is detected corectly, then maybe those in and out bits are "bad"...
    • bloodyskullz
      • Jan 2025
      • 52
      The original trigger was causing me more alerts for those 4 vms in particular, the new one has reduced it a bit in comparison but I am still getting them.
      What do you mean by the bits are bad?
        • 5004
        Wrong unit maybe? expected as bits but device returns some k/M/G bits? or vice versa?
        • bloodyskullz
          • Jan 2025
          • 52
          I double checked that as well:
          This is the default, its the same for every VM reporting into zabbix.
