Agent to Proxy connection issues on 7.4.7
  • caxton
    • Jan 2021
    I have used Zabbix for many years but have built my first environment with two Zabbix Servers using HA that have three proxy groups with two proxies in each group. I am also rolling out the agent 2 for the first time as well. In my testing with a few Linux and Windows systems, everything went well but as I have migrated the whole environment I have run into some odd connectivity issues. The whole setup is using active monitoring as that seems to work best so far but I do still have agents that stop sending data for no real reason. The systems that are giving me to most trouble are Windows desktops. Some seem to work fine with some agents going offline then some won't connect at all. It seems that in general, most of the agent issues are on systems running Windows.
    In the two proxies that these desktops are using, the log just streams this message with various IP addresses.
    2730:20260307:130730.000 failed to accept an incoming connection: from <IP_ADDRESS>: reading first byte from connection failed: [104] Connection reset by peer
    Any thoughts or suggestions would be greatly appreciated.
    Thanks,
    Cassius
