Issues during migration Zabbix 7.4.2 BD (MariaDB -> PSQL 17.x) using pgloader
  • Jaceqp
    • Mar 2026
    • 19
    Hi there.
    I've created new environment to fight my way through migration process. My current zabbix is 7.4.2 and recreated exact same version on my temporary vm's. Only difference is slightly different mariadb (10.11.15 vs 10.11.16).
    I found migration tutorial here:
    https://www.initmax.com/webinar/migr...to-postgresql/
    Obviously adjusted repos to my exact zabbix version.
    Before migrating mysql DB to postgres I shrinked it's size by manually trunking oldest db data in:
    alerts
    acknowledges
    events
    history
    history_uint
    history_str
    history_text
    history_log
    trends
    trends_uint
    I think built in housekeeper didn't really do the job. Anyway I managed to reduce DB size from ~25G to just 2.1G (keeping data not older than 7 days). Thats fine since I'm not really concerned atm on keeping history anyways. Without shrinking mysql DB I got some crazy errors like buffers overfilled (perhapse quite normal) but also 'KABOOM' errors.
    pgloader KABOOM! BROKEN-PIPE: Couldn t write to #<SB-SYS:FD-STREAM for socket 127.0.0.1:34172, peer: 127.0.0.1:3306 {100582A0D3}>: Broken pipe An unhandled error condition has been signalled:
    My trunking method was to rename tables to xxx_old, creating new ones "LIKE" old ones and pumping rows not older than xxx timestamp then remove old ones.
    After that zabbix still worked fine but something went wrong with events table - there were some dependencies in mysql logs showing missing events_old table.
    So I restored all events*** tables from former backup and left it unshrinked that way. Warnings were gone.
    OK. I promise u, back to migration itself
    All procedure went pretty smooth - 0 errors but after data migration on ALTER TABLE step (running alter_table.sql) there were few warnings:
    ALTER TABLE ONLY acknowledges ADD CONSTRAINT c_acknowledges_2 FOREIGN KEY (eventid) REFERENCES events (eventid) ON DELETE CASCADE;
    psql:/tmp/zabbix-db-migration/alter_table.sql:132: ERROR:  insert or update on table "acknowledges" violates foreign key constraint "c_acknowledges_2"
    DETAIL:  Key (eventid)=(14738788) is not present in table "events".
    ALTER TABLE ONLY event_tag ADD CONSTRAINT c_event_tag_1 FOREIGN KEY (eventid) REFERENCES events (eventid) ON DELETE CASCADE;
    psql:/tmp/zabbix-db-migration/alter_table.sql:158: ERROR:  insert or update on table "event_tag" violates foreign key constraint "c_event_tag_1"
    DETAIL:  Key (eventid)=(537) is not present in table "events".
    ALTER TABLE ONLY problem ADD CONSTRAINT c_problem_1 FOREIGN KEY (eventid) REFERENCES events (eventid) ON DELETE CASCADE;
    psql:/tmp/zabbix-db-migration/alter_table.sql:159: ERROR:  insert or update on table "problem" violates foreign key constraint "c_problem_1"
    ALTER TABLE ONLY event_recovery ADD CONSTRAINT c_event_recovery_1 FOREIGN KEY (eventid) REFERENCES events (eventid) ON DELETE CASCADE;
    psql:/tmp/zabbix-db-migration/alter_table.sql:165: ERROR:  insert or update on table "event_recovery" violates foreign key constraint "c_event_recovery_1"
    DETAIL:  Key (eventid)=(12763150) is not present in table "events".
    ALTER TABLE ONLY event_recovery ADD CONSTRAINT c_event_recovery_2 FOREIGN KEY (r_eventid) REFERENCES events (eventid) ON DELETE CASCADE;
    psql:/tmp/zabbix-db-migration/alter_table.sql:166: ERROR:  insert or update on table "event_recovery" violates foreign key constraint "c_event_recovery_2"
    DETAIL:  Key (r_eventid)=(12763217) is not present in table "events".
    ALTER TABLE ONLY event_suppress ADD CONSTRAINT c_event_suppress_1 FOREIGN KEY (eventid) REFERENCES events (eventid) ON DELETE CASCADE;
    psql:/tmp/zabbix-db-migration/alter_table.sql:208: ERROR:  insert or update on table "event_suppress" violates foreign key constraint "c_event_suppress_1"
    DETAIL:  Key (eventid)=(10376152) is not present in table "events".
    So still some issues related to 'events' I suppose.
    Despite that my zabbix seem to work yet I'm not sure it's a good idea to leave it just the way it is.
    I'm also considering wiping some tables clean (if needed or just to ensure data consistency - please feel free to guide me through). Obviously my main "no-touch"ies are hosts, users, templates,images etc. I'd like to keep my objects intact.
    I'm moving to postgres instead of mysql since mu future production environment preffers it. Also postgres 18 is yet not supported there - thats why I'm on 17.x atm.
    Anyway - any suggestions much apreciated.
    • 4996
    All it says is, that you have no such event in event table, what this acknowledge, event_tag or problem wants... You removed data manually, that means those acknowledges, problems etc, what you try to import, reference now noneisten event...
    Maybe you should reduce all the data retention periods from UI ​​and let housekeeper do its job (not instant, may take some days to keep up, if reduced a lot)... So all related records get removed with the event removal...
    • tim.mooney
      • Dec 2012
      • 1436
      I agree 100% with Cyber.
      How big is your events table? I can see using the "copy from old to empty table" procedure for any of the 5 history* tables, but I don't see why that would be useful or necessary for alerts, acknowledges, events, or the trends tables. Those shouldn't be all that big.
      Assuming your housekeeper finishes in a reasonable amount of time with your MariaDB install, you can force it to run more frequently than hourly or whatever it's running at. If you know e.g. that every housekeeper run takes between 7 minutes and 7 minutes 30 seconds (or whatever for your environment), you can run it in a loop from the command line, with a long-enough delay between runs. See the documentation for the '-R' flag for zabbix_server.
      Tim
        • 4996
        Trends tables can be quite big.. I just copied over from one instance to another... trends tables .. ~60 million rows per month.. history tables 500M rows per day..:P Also auditlog table is damn huge, if you keep all of it for a year..:P
        But with the 25G DB I would not even bother to shrink it..:P 1T... maybe, maybe not...
        • Jaceqp
          • Mar 2026
          • 19
          I wonder if despite these errors data itself is consistent... or NOT.
          Should I repeat the process or leave it just the way things are. I've reconfigured housekeeping from GUI to 1-2d max.
          It seems to be working - once in a while in zabbix-server logs:
          housekeeper [deleted 1677082 hist/trends, 0 items/triggers, 207 events, 6 problems, 0 sessions, 0 alarms, 0 audit, 0 autoreg_host, 0 records in 57.624764 sec, idle for 1 hour(s)]
          • Jaceqp
            • Mar 2026
            • 19
            Tim
            My work-in-progress zabbix using Postgres - trends table has 63M atm, while actual production zabbix (using unshrinked mysql db) has 671M.
            Here's larger table list of old zabbix (smallest ones skipped):
            | Database | Table | Size (MB) |
            | zabbix | history_uint | 12998 |
            | zabbix | history | 9783 |
            | zabbix | trends_uint | 837 |
            | zabbix | history_text | 794 |
            | zabbix | history_str | 743 |
            | zabbix | trends | 671 |
            | zabbix | items | 32 |
            | zabbix | events | 22 |
            | zabbix | event_tag | 21 |
            | zabbix | widget_field | 20 |
            | zabbix | images | 18 |
            | zabbix | history_log | 16 |
            | zabbix | auditlog | 15 |
            | zabbix | triggers | 13 |
            | zabbix | event_recovery | 8 |
            | zabbix | functions | 7 |
            | zabbix | item_tag | 5 |
            | zabbix | valuemap_mapping | 4 |
            | zabbix | item_discovery | 4 |
            And for a better view of zabbix load and infrastructure size here are some numbers(production):
            ​​​​Click image for larger version
            vs new (obviously most hosts have no agent connection to new zabbix server, also disabled hosts coming in from inaccessible (atm) proxies...
              • 4996
              those errors above (as long as I understand) mean, that your insert was not successful ... So your data was not inserted, not consistent...
              • tim.mooney
                • Dec 2012
                • 1436
                Oof, I stand corrected. Glad I don't have to deal with the install size that you work with!
                For Jaceqp's table sizes, though, I wouldn't bother shrinking anything except the history* tables. My hope is that if you use the full tables for most stuff but skip some of the data in history*, that will be enough to avoid the pgloader error you mentioned. It's also possible you could avoid the error with some kind of tuning in your pgloader script, but I'm no expert on pgloader so I'm not sure.
                Regarding Jaceqp's housekeeper: it only takes 57 seconds to run, so Jaceqp could be running it 40-50 times per hour, to trigger faster cleanup on the old host.
                • Jaceqp
                  • Mar 2026
                  • 19
                  Is it safe enough to cut out all hitory tables like this:
                  DELETE FROM history WHERE (UNIX_TIMESTAMP(NOW()) - clock) > (@history_interval * 24 * 60 * 60);
                  DELETE FROM history_uint WHERE (UNIX_TIMESTAMP(NOW()) - clock) > (@history_interval * 24 * 60 * 60);
                  DELETE FROM history_str WHERE (UNIX_TIMESTAMP(NOW()) - clock) > (@history_interval * 24 * 60 * 60);
                  DELETE FROM history_text WHERE (UNIX_TIMESTAMP(NOW()) - clock) > (@history_interval * 24 * 60 * 60);
                  DELETE FROM history_log WHERE (UNIX_TIMESTAMP(NOW()) - clock) > (@history_interval * 24 * 60 * 60);
                  My biggest uncut tables are:
                  history_uint = 13G
                  history = 10G
                  Not sure I can shrink these two leaving other history* intact.
                  Why am I trying to shrink db size is to make convert go faster and without some unnecessary data. Besides 1st attemps of migrating DB to Postgres failed not sure why perhapse timeouts on operation itself, perhapse overfilled resources.
                    • 4996
                    history/trends tables are the lucky ones, which just contain data, no links to other tables. So dropping data from them will not hurt anything.
                    You can also just export that data to file and load it later to new DB.. (not sure exact sql-s in case of mysql to export data to CSV file for example and later using "COPY table FROM 'file'" for PG).
                    • Jaceqp
                      • Mar 2026
                      • 19
                      I'll try to throw away history/trends data then. Any recomendations on that? I've restored mysql copy (uncut for now). Perhapse replacing those with empty schemas instead of cutting out? I'm still learning on DB maintenance... Any tips on that?
                      BTW. Checking DB size on old zabbix server shows ~26G while restored on a new one from backup sql file shows only 15G. Should I be concerned or it just shrinked by writing non-empty rows only and it's normal?
                        • 4996
                        It may be the truncating of empty space.
                        If you do not want any history and trends, just dont copy them.
                        • Jaceqp
                          • Mar 2026
                          • 19
                          I restored mysql backup, then DROP'ped history and trends tables, created another 'itemplate' zabbix DB and copied all missing tables into main DB. That seems to work (at least for now)... obviously no history data yet DB size shows ca 200MB.
