Spaces in Item keys is causing issues.
  • Items_KS
    • Aug 2017
    Hello everyone,
    we are currently working on a Zabbix with a lot of different devices, everything worked out perfectly till now.
    Our current problem is: We want to make MAPS with Traffics Macros like
    in: 58KB/s
    out: 56KB/s
    which works perfectly fine on most devices but now we tried it on an "AVAYA" device, which reports its keys as "ifInOctets[Avaya Ethernet Routing Switch 4850GTS-PWR+ Module - Unit 2 Port 50 ]" I made my Macro as usual like:
    "in: {{HOST.HOST}:ifInOctets[Avaya Ethernet Routing Switch 4850GTS-PWR+ Module - Unit 2 Port 50 ].last(0)}"
    but everything it reports is *UNKNOWN*, if I use the same method on any other device it works perfectly fine.
    It seems that Zabbix has an issue with spacebars in the Keys, is there any workaround?
    Thanks for your help, have a nice day!
