zabbix db character set conversion/recommendations
  • Jaceqp
    • Mar 2026
    • 19
    Hi there.
    I've just created empty MySQL zabbix DB using
    create database zabbix character set utf8mb4 collate utf8mb4_bin;
    then restored DB using sql file from another server (create DB not included in script).
    mysql -uroot -p zabbix < /somepath/somefile.sql
    After restoring DB and checking SELECT @@character_set_database, @@collation_database; shows:
    MariaDB [zabbix]> SELECT @@character_set_database, @@collation_database;
    | @@character_set_database | @@collation_database |
    | utf8mb3                  | utf8mb3_bin          |
    Seems charset is included in .sql itself. Shall I convert DB to utf8umb4 anyway or leave it as it is?
    • 5004
    As it is meant to be utfmb4, then convert it... Or recreate that DB again, but try to find that part of your sql that forced wrong charset and fix it before...
    • guntis_liepins
      • Oct 2025
      • 61
      When I restore database I always create it beforehand with utf8mb4 utf8mb4_bin. Do not leave it utf8mb3 , it will not work correctly , it is in documentation.
