Create simple trigger in Zabbix
  • ColdRaker
    • Aug 2017
    I'm trying to add a trigger in Zabbix. My script simply checks for some data and returns 1 for errors and 0 if everything is good.
    The Trigger is: {Hostname:Key.last()}=1
    On the Host, by testing the triggerdata via the agent, I get the value 1 back and the powershellscript returns 1 too.
    Now here is the confusing part
    The latest data in the webinterface shows 0 as value
    I already tried to restart the agent and recreated the trigger.
    I checked the script several times. Thats not the problem! (But if you insist I can post it. )
    Did anyone have a similar problem so far? (I use Zabbix 3.2)
    I gladly accept any ideas
    Best Regards
    Cold
  • ColdRaker
    • Aug 2017
    solved
    I found the problem.
    It was a simple permission issue. The script checks for a file on a VM, but the zabbix service didnt have the rights to access the VM.
    Thats the reason why everything worked fine when running it manually...
