API event.get groupids not working
  • pqespindola
    • Aug 2017
    Hello everyone,
    I noticed that after upgrading zabbix-frontend-php from 3.2.6 to 3.2.7, API event.get requests with "groupids" or "hostids" field return empty:
    REQUEST:
    "jsonrpc": "2.0",
    "method": "event.get",
    "params": {
    "groupids":"10",
    "output": "extend",
    "time_from":"1497916800",
    "time_till":"1503600498",
    "id": 1,
    "auth": "{{token}}"
    RESPONSE:
    "jsonrpc": "2.0",
    "result": [],
    "id": 1
    If I restore a snapshot with the exact same request on 3.2.6 everything works fine. No groupids or hostids work. Requests without these 2 fields work fine. The "objectid" field works as well.
    Were there any known changes to the way event.get works? Does anyone know any workaround?
    Thanks in advance
    Update:
    The same happens in 3.4.1.
    Replacing .../includes/classes/api/services/CEvents.php with the one from 3.2.6 works.
    The OS is Ubuntu 14.04.5
  • .sys
    • Oct 2017
    Related bug report here:
    Fixed in:
    - 3.2.9rc1 r72912
    - 3.4.3rc1 r72913
    - 4.0.0alpha1 (trunk) r72914
