Incorrect Disk partition details
  • PD77
    • Aug 2017
    Hello All,
    I have zabbix 3.2 installed in CentOS 6.9 server.
    In zabbix GUI, I am getting correct disk information of / & /boot partitions but the disk space details of /data partition in GUI is incorrect. I ran zabbix_agend -t vfs.fs.size[] command on the client. I can retrieve the correct disk space details of /data using the above command . but in the graph and in the latest data of /data partition is incorrect in Zabbix GUI .
    On the client:
    zabbix_agentd -t vfs.fs.size[/,total]
    vfs.fs.size[/,total] [u|27881500672]
    zabbix_agentd -t vfs.fs.size[/boot,total]
    vfs.fs.size[/boot,total] [u|499355648]
    zabbix_agentd -t vfs.fs.size[/data,total]
    vfs.fs.size[/data,total] [u|107320315904]
    df -h
    Filesystem Size Used Avail Use% Mounted on
    /dev/mapper/vg_c6-lv_root
    26G 6.8G 18G 28% /
    tmpfs 3.8G 0 3.8G 0% /dev/shm
    /dev/sda1 477M 174M 279M 39% /boot
    /dev/sdb5 100G 43G 58G 43% /data
    I have attached screenshot of the graph. Hope you can view it. Any help will be much appreciated.
