We are running into continuous issues of the Zabbix database getting filled up too quickly. Within 1 month the Zabbix sucked up ~50GB. We expanded the monitoring system to other users and see it being slightly abused. When confronted they did mention that they need to retain most of the data for the time period.
I have already increased the Database twice to a larger disk but don't want to keep performing this. I would like a fully self-contained, scalable environment regarding space of the database. I would like to build the environment to be able to handle the abuse from other users.
Thus my questions are as follows:
1. Are there any recommend postgresql scaling articles for handling hundreds and thousands of metrics and potentially 1000s of hosts?
2. How do I check which database entries (psql commands) take up the most space from which host? Is there any easy way to check this via an API command to the frontend instead of sifting through 100s of hosts?
3. Is a HA database scenario recommended to help with performance?
4. Is there a blueprint for the recommended database size to handle a certain amount of metrics, hosts, items?
5. For large scale environments what shall be modified on the /etc/zabbix/zabbix_server.conf file to address Housekeeping? Shall it be maxed out?
Any recommended information is highly appreciated.
