Trigger for net.dns.get with macros
  • pvsa
    • Dec 2024
    Zabbix team since years. Thanks for building reliable monitoring software open source!
    I started to setup a DNS Integrity Check with an item like net.dns.get[1.1.1.1,{HOST.DNS},A,3,1] combined with preprocessing JSONPath "$.answer_section[0].rdata.a"
    and a trigger last(/mails2/net.dns.get[1.1.1.1,{HOST.DNS},A,3,1],#1)<>"{HOST.IP}" - in the assumption that it would work like example 16 here https://www.zabbix.com/documentation...ers/expression
    But this is not the case.
    Latest data shows the right value, but the trigger does not alert correctly. I've tried text and character and even last and find function without success.
    Another thing that surprises me, was that when importing a pre-generated template - i can use
    triggers:
    - uuid: e345742d3a1b4bbe8c2a83a4ac4db28a
    expression: 'find(/Template DNS Integrity Check/net.dns.get[,{HOST.DNS},A,3,1],#1,"like","{HOST.IP}")=0'
    name: 'DNS Mismatch [System DNS]: Forward lookup of {HOST.DNS} returned wrong IP'
    opdata: 'Expected: {HOST.IP} | Got: {ITEM.LASTVALUE}'
    priority: HIGH
    description: 'System DNS resolved {HOST.DNS} to an IP that does not match {HOST.IP}.'
    But i didn't find a way to configure this with the dialog.
    zabbix server 7.4.6 and agent version 2 (7.4.2)
    I'm was not sure it net.dns.get is already officially supported as it is not in the "Standard items" list from item key drop down. Of course i could use the net.dns.record but I think it's worth to ask.
    BrP
  • Answer selected by pvsa at 26-07-2026, 14:16.
    pvsa
    • Dec 2024
    Hi cyber,
    thanks for the guidance. In the meantime, I found out that one can't use built-in macros with trigger in general https://www.zabbix.com/documentation...ed_by_location
    Therefor i switched to LLD (low level discovery) and this did the trick: https://github.com/pvsa/pnet-suite/b..._dns_check.xml
    • pvsa
      • Dec 2024
      Really no one uses net.dns.get with triggers ?
      i did not find any evidence in the changelog for bugs in that area.
        • 4996
        net.dns.get is part of agent2.. It is not working with classic agent.
        • pvsa
          • Dec 2024
          Hi cyber,
