Update interval for discovery item prototype not working
  • dwoodwoo
    • Aug 2017
    I'm using Zabbix 3.2.6. I have a database monitor discovery rule to find all non-model databases on SQL Server (select name AS dbname from sysdatabases where name != 'model'). The update interval is set to 3600s. This is working fine.
    I'm trying to set a 300s update interval for an item prototype; however, it seems to be ignored. There is no custom interval defined. To prove it's not working ... I created a simple test item prototype:
    Type: Database monitor
    Key: db.odbc.select[foo_{#DBNAME},{HOST.NAME}]
    SQL query: insert into foo values('{#DBNAME}',GetDate())
    Update interval: 300
    Results on SQL Server:
    select TOP 5 * from foo where dbname = 'master' order by cdate desc
    dbname cdate
    master 2017-08-30 22:13:56.877
    master 2017-08-30 22:12:56.723
    master 2017-08-30 22:11:56.050
    master 2017-08-30 22:10:56.633
    master 2017-08-30 22:09:56.210
    As you can see, it's running every minute, so the 300s update interval seems to be ignored. What am I doing wrong?
    Thank you! David
  • dwoodwoo
    • Aug 2017
    I also tried:
    • setting the update interval to 0
    • creating a custom scheduling interval: m/5
    Results are the same as before, it's running every minute, instead of every 5 minutes.
    Any ideas?
    • allexpetrov
      • May 2017
      • 361
      Have you tried to use flexible?
      Interval: 300 Period: 1-7,00:00-24:00, also your Items would be recreated on the next LLD run.
      Regards,
      Alex!
