Please I need your help!
I've created an item with the following:
Server: Zabbix 2.4
Monitored: Windows Server 2008 R2
Item:
type: Zabbix agent (active)
key: logrt["K:\Impact360\Data\Logs\integrationservice\integra tionservice_[0-9]+_[0-9]+_[0-9]+_[0-9]+","Str<0> = Miraflores ; Str<1> = [0-9]+/[0-9]+ ; Int<2> = ([0-9]+)",,,skip,\1]
Status: Not supported
Info: Cannot open directory "\\" for reading: [22] Invalid argument
log from zabbix_agentd.log:
7144:20170831:105505.130 In process_active_checks() server:'10.10.92.5' port:10051)
7144:20170831:105505.140 In process_logrt() is_logrt:1 filename:'K:\Impact360\Data\Logs\integrationservic e\integrationservice_[0-9]+_[0-9]+_[0-9]+_[0-9]+' lastlogsize:40786266 mtime:1504194514 error_count:0
7144:20170831:105505.140 In split_filename() filename:'K:\Impact360\Data\Logs\integrationservic e\integrationservice_[0-9]+_[0-9]+_[0-9]+_[0-9]+'
7144:20170831:105505.140 split_filename() K:\Impact360\Data\Logs\integrationservice\integrat ionservice_[0-9]+_[0-9]+_[0-9]+_[0-9]+
7144:20170831:105505.140 split_filename() ^
7144:20170831:105505.140 In split_string() str:'K:\Impact360\Data\Logs\integrationservice\int egrationservice_[0-9]+_[0-9]+_[0-9]+_[0-9]+' del:'\integrationservice_[0-9]+_[0-9]+_[0-9]+_[0-9]+'
7144:20170831:105505.140 End of split_string():SUCCEED part1:'K:\Impact360\Data\Logs\integrationservice\' part2:'integrationservice_[0-9]+_[0-9]+_[0-9]+_[0-9]+'
7144:20170831:105505.140 End of split_filename():SUCCEED directory:'K:\Impact360\Data\Logs\integrationservi ce\' format:'integrationservice_[0-9]+_[0-9]+_[0-9]+_[0-9]+'
7144:20170831:105505.150 log files reside on 'NTFS' file system
7144:20170831:105505.180 In add_logfile() filename:'K:\Impact360\Data\Logs\integrationservic e\integrationservice_2017_08_31_0081.zip' mtime:1504194514 size:96717865
7144:20170831:105505.180 add_logfile() logfiles:0000000000C93DC0 logfiles_alloc:64
7144:20170831:105505.180 End of add_logfile()
7144:20170831:105505.180 In add_logfile() filename:'K:\Impact360\Data\Logs\integrationservic e\integrationservice_2017_08_31_0091.zip' mtime:1504194758 size:19455923
7144:20170831:105505.180 In add_logfile() filename:'K:\Impact360\Data\Logs\integrationservic e\integrationservice_2017_08_31_0093.log' mtime:1504194875 size:67109709
7144:20170831:105505.190 End of add_logfile()
7144:20170831:105505.200 In add_logfile() filename:'K:\Impact360\Data\Logs\integrationservic e\integrationservice_2017_08_31_0094.log' mtime:1504194904 size:17893949
7144:20170831:105505.200 End of add_logfile()
7144:20170831:105505.220 setup_old2new: is_same_file(K:\Impact360\Data\Logs\integrationser vice\integrationservice_2017_08_31_0081.zip, K:\Impact360\Data\Logs\integrationservice\integrat ionservice_2017_08_31_0081.zip) = 1
7144:20170831:105505.220 setup_old2new: is_same_file(K:\Impact360\Data\Logs\integrationser vice\integrationservice_2017_08_31_0081.zip, K:\Impact360\Data\Logs\integrationservice\integrat ionservice_2017_08_31_0091.zip) = 0
7144:20170831:105505.220 setup_old2new: is_same_file(K:\Impact360\Data\Logs\integrationser vice\integrationservice_2017_08_31_0081.zip, K:\Impact360\Data\Logs\integrationservice\integrat ionservice_2017_08_31_0093.log) = 0
7144:20170831:105505.220 setup_old2new: is_same_file(K:\Impact360\Data\Logs\integrationser vice\integrationservice_2017_08_31_0081.zip, K:\Impact360\Data\Logs\integrationservice\integrat ionservice_2017_08_31_0094.log) = 0
7144:20170831:105505.220 setup_old2new: is_same_file(K:\Impact360\Data\Logs\integrationser vice\integrationservice_2017_08_31_0091.log, K:\Impact360\Data\Logs\integrationservice\integrat ionservice_2017_08_31_0081.zip) = 0
7144:20170831:105505.220 setup_old2new: is_same_file(K:\Impact360\Data\Logs\integrationser vice\integrationservice_2017_08_31_0091.log, K:\Impact360\Data\Logs\integrationservice\integrat ionservice_2017_08_31_0091.zip) = 0
7144:20170831:105505.220 setup_old2new: is_same_file(K:\Impact360\Data\Logs\integrationser vice\integrationservice_2017_08_31_0091.log, K:\Impact360\Data\Logs\integrationservice\integrat ionservice_2017_08_31_0093.log) = 0
7144:20170831:105505.220 setup_old2new: is_same_file(K:\Impact360\Data\Logs\integrationser vice\integrationservice_2017_08_31_0091.log, K:\Impact360\Data\Logs\integrationservice\integrat ionservice_2017_08_31_0094.log) = 0
7144:20170831:105505.220 setup_old2new: is_same_file(K:\Impact360\Data\Logs\integrationser vice\integrationservice_2017_08_31_0092.log, K:\Impact360\Data\Logs\integrationservice\integrat ionservice_2017_08_31_0081.zip) = 0
7144:20170831:105505.220 setup_old2new: is_same_file(K:\Impact360\Data\Logs\integrationser vice\integrationservice_2017_08_31_0092.log, K:\Impact360\Data\Logs\integrationservice\integrat ionservice_2017_08_31_0091.zip) = 0
7144:20170831:105505.220 setup_old2new: is_same_file(K:\Impact360\Data\Logs\integrationser vice\integrationservice_2017_08_31_0092.log, K:\Impact360\Data\Logs\integrationservice\integrat ionservice_2017_08_31_0093.log) = 0
7144:20170831:105505.230 setup_old2new: is_same_file(K:\Impact360\Data\Logs\integrationser vice\integrationservice_2017_08_31_0092.log, K:\Impact360\Data\Logs\integrationservice\integrat ionservice_2017_08_31_0094.log) = 0
7144:20170831:105505.230 setup_old2new: is_same_file(K:\Impact360\Data\Logs\integrationser vice\integrationservice_2017_08_31_0093.log, K:\Impact360\Data\Logs\integrationservice\integrat ionservice_2017_08_31_0081.zip) = 0
7144:20170831:105505.230 setup_old2new: is_same_file(K:\Impact360\Data\Logs\integrationser vice\integrationservice_2017_08_31_0093.log, K:\Impact360\Data\Logs\integrationservice\integrat ionservice_2017_08_31_0091.zip) = 0
7144:20170831:105505.230 setup_old2new: is_same_file(K:\Impact360\Data\Logs\integrationser vice\integrationservice_2017_08_31_0093.log, K:\Impact360\Data\Logs\integrationservice\integrat ionservice_2017_08_31_0093.log) = 1
7144:20170831:105505.230 setup_old2new: is_same_file(K:\Impact360\Data\Logs\integrationser vice\integrationservice_2017_08_31_0093.log, K:\Impact360\Data\Logs\integrationservice\integrat ionservice_2017_08_31_0094.log) = 0
7144:20170831:105505.230 process_logrt() old file list:
7144:20170831:105505.230 nr:0 filename:'K:\Impact360\Data\Logs\integrationservic e\integrationservice_2017_08_31_0081.zip' mtime:1504194514 size:96717865 processed_size:40786266 seq:1 incomplete:0 dev:4232431421 ino_hi:0 ino_lo:58265320179108906 md5size:512 md5buf:7df9a7aee5338daf490756aac7267955
7144:20170831:105505.230 nr:1 filename:'K:\Impact360\Data\Logs\integrationservic e\integrationservice_2017_08_31_0091.log' mtime:1504194632 size:67109023 processed_size:0 seq:0 incomplete:0 dev:4232431421 ino_hi:0 ino_lo:157063037004546449 md5size:512 md5buf:0e1882f25148c35898ea313d7fd08f86
7144:20170831:105505.230 nr:2 filename:'K:\Impact360\Data\Logs\integrationservic e\integrationservice_2017_08_31_0092.log' mtime:1504194758 size:67109068 processed_size:0 seq:0 incomplete:0 dev:4232431421 ino_hi:0 ino_lo:250794204249195902 md5size:512 md5buf:c8870926ca6561e0817e8a88a119f0e6
7144:20170831:105505.230 nr:3 filename:'K:\Impact360\Data\Logs\integrationservic e\integrationservice_2017_08_31_0093.log' mtime:1504194783 size:15452686 processed_size:0 seq:0 incomplete:0 dev:4232431421 ino_hi:0 ino_lo:73464968921484321 md5size:512 md5buf:3f9ac0a65523085057b4c4b00d6084c9
7144:20170831:105505.230 process_logrt() new file list: (mtime:1504194514 lastlogsize:40786266 start_idx:0)
7144:20170831:105505.230 nr:0 filename:'K:\Impact360\Data\Logs\integrationservic e\integrationservice_2017_08_31_0081.zip' mtime:1504194514 size:96717865 processed_size:40786266 seq:0 incomplete:0 dev:4232431421 ino_hi:0 ino_lo:58265320179108906 md5size:512 md5buf:7df9a7aee5338daf490756aac7267955
7144:20170831:105505.240 nr:1 filename:'K:\Impact360\Data\Logs\integrationservic e\integrationservice_2017_08_31_0091.zip' mtime:1504194758 size:19455923 processed_size:0 seq:0 incomplete:0 dev:4232431421 ino_hi:0 ino_lo:65302194596875309 md5size:512 md5buf:6f86dd311bcf09ead5f6d9d462873a1c
7144:20170831:105505.240 nr:2 filename:'K:\Impact360\Data\Logs\integrationservic e\integrationservice_2017_08_31_0093.log' mtime:1504194875 size:67109709 processed_size:0 seq:0 incomplete:0 dev:4232431421 ino_hi:0 ino_lo:73464968921484321 md5size:512 md5buf:3f9ac0a65523085057b4c4b00d6084c9
7144:20170831:105505.240 nr:3 filename:'K:\Impact360\Data\Logs\integrationservic e\integrationservice_2017_08_31_0094.log' mtime:1504194904 size:17893949 processed_size:0 seq:0 incomplete:0 dev:4232431421 ino_hi:0 ino_lo:91479367430966315 md5size:512 md5buf:1fde1fbef11707370b19bebb3d92950b
7144:20170831:105505.240 In process_log() filename:'K:\Impact360\Data\Logs\integrationservic e\integrationservice_2017_08_31_0081.zip' lastlogsize:40786266 mtime: 1504194514
3924:20170831:105505.360 In collect_perfstat()
3924:20170831:105505.360 End of collect_perfstat()
7144:20170831:105505.480 End of process_log() filename:'K:\Impact360\Data\Logs\integrationservic e\integrationservice_2017_08_31_0081.zip' lastlogsize:43910449 mtime: 1504194514 ret:SUCCEED
7144:20170831:105505.480 End of process_logrt():SUCCEED error_count:0
7144:20170831:105505.480 End of process_active_checks()
Server: Zabbix 2.4
Item:
