Cannot connect to the database
  • Sandeep
    • Jun 2026
    Hi Everyone. I am new to Zabbix and trying to install zabbix 7.4 with mysql 8 on single node.
    Installation went fine and all services came up without any issues and I am able to connect to the internet using localhost and creds through CLI.
    But, coming to webserver, it throws error saying cannot connect to the database. Can someone please help me to fix the issue
  • tim.mooney
    • Dec 2012
    • 1436
    The web interface can be run on a separate system (mostly for large deployments), so it needs to get its most basic configuration from a separate config file from what the Zabbix server reads. Look in the web root in the 'conf' directory for a file named 'zabbix.conf.php' That needs to contain database configuration before the web interface will be able to connect to the database.
    • Sandeep
      Sandeep commented
      Thank you for the reply.
