Zabbix 7.4.9 unable to get scheduled reports working.
  • rbpowell
    • May 2026
    I have an Ubuntu 24.04 running docker, my setup is a docker compose file with the following services PostgreSQL, Zabbix 7.4.9 Server, Nginx Web interface, Web Service, headless chrome, Agent 2, snmp Traps, Java Gateway, all running in same network subnet. I have added all of the variables for scheduled reporting. WebServiceURL, Allowed IP, Listening port, Frontend URL are all set, all testing shows everything working. When I run the test for the report I get this error:
    2026/06/10 18:07:05.016034 received report request from 172.30.240.0:48568
    2026/06/10 18:07:05.016498 making chrome headless request with parameters url: http://my.internal.com/zabbix.php?ac...shboardid=405& from=2026-06-09%2000%3A00%3A00&to=2026-06-10%2000%3A00%3A00, width: 1920, height: 1080 for report request from 172.30.240.0:48568
    10 18:07:36.190650 Cannot fetch data.: dashboard failed to get ready, url: 'http://my.internal.com/zabbix.php?action=dashboard.print&dashboardid=405& from=2026-06-09%2000%3A00%3A00&to=2026-06-10%2000%3A00%3A00': Inspected target navigated or closed (-32000).
    I can take the URL listed in the error and paste it into a browser and it opens the Dashboard in 2 secs. Guessing but the error sounds like something to do with chrome, but I have not been able to figure it out. Chrome is running and all tests shows it as working correctly and the configuration test all show good. I have even tried running chrome direct instead of a container on the server with the same error message.
    Any help with this would be greatly appreciated.
  • Alex28
    • Aug 2023
    • 14
    Hi, were you able to fix it? I had the same error and solved it by changing the URL under Administration / General / Other... the Frontend URL needs to be accessible.
    • rbpowell
      • May 2026
      No, still having the same issue. The Frontend URL is accessible. Tried with just IP address and domain name, both worked during testing, but still get the same error.
      • Rudlafik
        • Nov 2018
        • 168
        I try long time ago this: (other problem but maybe inspiration for you)
        Originally posted by Rudlafik
        Our resolution is:
        1. Administration -> General -> Other: Fronend URL: https://Yours.DNS.adr
        2.Zabbix server config: WebServiceURL=http://Yours.DNS.adr:10053/report
        3.Web service config:
        TLSAccept=unencrypted
        IgnoreURLCertErrors=1
        Its work for us :-) Not blank PDF
        • rbpowell
          • May 2026
          Thanks for the reply. I tried with the TLSAccept=unencrypted under the Web Service, still same error. I already had all of the other settings including the IgnoreURLCertErrors.
          • Rudlafik
            • Nov 2018
            • 168
            Try it again on new deasboard -only with clock | CPU zabbix server. Try test simply deshboard
            check al way from container routing/proxy/DNS mayby diferent look of wrontend
            check that frontend fom container correct conect to ZBX srv.
            life buoy - diferent version of component od bug in 7.4.9 (try on older or new version)
            • rbpowell
              • May 2026
              My test is just the Zabbix server dashboard. Everything I can find is showing working correctly, only issues is the actual error message when running the test itself. We had a previous version 7.4.5, it worked fine, may try and go back a couple of versions.
