Logrt and zabbix agents 3.4 issue
  • n3o
    • Jun 2016
    • 27
    Hello all ,
    I need your help with logrt.
    So I have updated my zabbix agents on 2 of my servers to v3.4 and now my logrt is not working on them. On the rest servers which I have v3.2 its working fine.
    see below my Item and Trigger... Please note that the log files I am monitoring have this format: 20170911.log and every day it changes to the next day 20170912.log ...20170913.log etc etc.
    The error I get is:
    3752:20170911:093116.157 active check "logrt[C:\Program Files (x86)\MetaTrader Data Center Demo1\logs\*.*,,,,skip,]" is not supported: Cannot compile a regular expression describing filename pattern: ? * + invalid at offset 0
    If there is a different way on which I can monitor these kind of files (20170912.log ...20170913.log etc etc.) I will appreciate it if you share it with me.
    This is my ITEM
    This is my Trigger
    Problem Expression: {serv1:logrt[C:\Program Files (x86)\MetaTrader Data Center
        Demo1\logs\*.*,,,,skip,].str(Datafeed: no connection )}=1
        Recovery Expression: {serv1:logrt[C:\Program Files (x86)\MetaTrader Data Center
        Demo1\logs\*.*,,,,skip,].str(Datafeed: started)}=1
  • n3o
    • Jun 2016
    • 27
    The problem is fixed with the below changes in the Item.
    See Item below:
    logrt[C:\\Program Files (x86)\\MetaTrader Data Center\\logs\\.*,,,,skip,]
