Value of item system.cpu.load[percpu,avg1] > 2
  • wyang
    • Mar 2016
    • 93
    The item system.cpu.load[percpu,avg1] monitors the per core CPU load, which is expected to be <= 1.
    However, the values of the item system.cpu.load[percpu,avg1] on two servers display > 2 for somewhile.
    Any idea on why? Thanks.
    Zabbix server version: 2.4
    Zabbix agent version: 2.4
  • jpomorski
    • Jul 2013
    Percpu parameter divide system cpu load value by numer of cores. So if your system cpu load is for example 8 and you have 4 cores, you get value 2.
    Jarek
    • wyang
      • Mar 2016
      • 93
      Thanks very much for the reply.
      From some Internet resources on understanding Linux CPU load, it is stated "the '100% utilization' mark is 1.00 on a single-core system." Therefore, I expect that the max value of the item system.cpu.load[percpu,avg1] <=1.
      However, monitoring history shows that the maximum values of the item system.cpu.load[percpu,avg1] on two servers display > 2.4
      Any idea on why? Thanks very much!
