HTTP Agent causes hanging CLOSE_WAIT connections in Docker container
  • Shadown
    • Jul 2026
    Hello everyone,
    I’m running into an issue with my Zabbix setup while monitoring a Proxmox environment using the official “Proxmox VE by HTTP” template.
    • Zabbix Server is running inside a Docker container.
    • Proxmox hosts are monitored via the official HTTP template.
    • The connection to the Proxmox API is made over port 8006.
    • The Proxmox host is reachable via IP, for example 192.168.210.2:8006.
    • Server version: 7.4.12
    After a short runtime of about 15 to 30 minutes, the TCP connections to the Proxmox API get stuck in the CLOSE_WAIT state.
    tcp        1      0 34a1a00fcd10:52880      192.168.210.2:8006      CLOSE_WAIT
    tcp        1      0 34a1a00fcd10:35162      192.168.210.2:8006      CLOSE_WAIT
    tcp        1      0 34a1a00fcd10:47348      192.168.210.2:8006      CLOSE_WAIT
    tcp        1      0 34a1a00fcd10:57528      192.168.210.2:8006      CLOSE_WAIT
    tcp        1      0 34a1a00fcd10:56086      192.168.210.2:8006      CLOSE_WAIT
    This is my Docker Compose configuration for the Zabbix server:
    zabbix-server:
        image: zabbix/zabbix-server-pgsql:alpine-7.4-latest
        #ulimits:
        # nproc: 65535
        # nofile:
        #  soft: 20000
        #  hard: 40000
        container_name: zabbix-server
        restart: unless-stopped
        depends_on:
          - postgresql-server
        environment:
          DB_SERVER_HOST: postgresql-server
          POSTGRES_USER: ${POSTGRES_USER}
          POSTGRES_PASSWORD: ${POSTGRES_PASSWORD}
          POSTGRES_DB: ${POSTGRES_DB}
          ZBX_NODEADDRESS: zabbix-server
          ZBX_NODEADDRESSPORT: 10051
          ZBX_STARTREPORTWRITERS: 3
          ZBX_WEBSERVICEURL: "http://zabbix-web-service:10053/report"
          ZBX_STARTHTTPPOLLERS: 1
          ZBX_DEBUGLEVEL: 3
          CURL_IPRESOLVE: 4
        ports:
          - "10051:10051"
        volumes:
          - zabbix-server-data:/var/lib/zabbix
          - zabbix-snmptraps-data:/var/lib/zabbix/snmptraps
          - zabbix-export-data:/var/lib/zabbix/export​
    When I enable the ulimit parameters, the issue still persists, but it takes longer to occur.​
  • bbrendon
    • Sep 2005
    • 873
    HI!
    I've been having a problem with HTTP Agent since updating from 7.4.9 to 7.4.12.
    My HTTP Agent item is reporting this error:
    Cannot perform request: Failed to connect to 10.1.1.128:80 after 0 ms: Could not connect to server
    Also
    de87bd73b7b5:/var/lib/zabbix# netstat -tn|grep 10.1.1.26|grep CLOSE_W|wc -l
    994
    de87bd73b7b5:/var/lib/zabbix# netstat -tn|grep CLOSE_W|wc -l
    994
    Related?
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • Shadown
      • Jul 2026
      Thank you very much for the tip.
      I downgraded curl to version 8.20.0 as described in the Known Issues section, and it looks like everything is working again.
