zabbix configuration for port 443 on nginx,mysql,php raspberry pi
  • colporteur
    • Jul 2026
    How to configure zabbix on an 8G Raspberry pi 5 OS (13 (trixie)), nginx (1.26.3-3+deb13u7), mysql (5.8+1.1.1), php-mysql (2:8.4+101) & zabbix (1:7.4.13-1+debian13) to support https using self-signed-certificates.
    I have installed nginx and have it working on port 433 using the self-signed-certificates. I then installed php and it serves webpage on 443. I then installed mysql and finally zabbix. I can connect to the zabbix web interface console <IP>:443 but the error message at the bottom indicates Zabbix Server is not running:the information displayed may not be current.
    Before starting the project to use port 443, I built a zabbix server using the same configuration on port 8080. The install is working. I have configured a few devices and am gathering data.
    I am a new user to zabbix. No experience at all! After evaluating a few products I landed here. The goal is to replace the MikroTik Dude server with zabbix. If someone could share their knowledge or point me in the direction of https configuration resources, that would be appreciated.
    So far I have tried internet searches and cull this forum looking for hints. After to many attempts to continue to count, I ask for help.
    I’m close to making it work, just not close enough.
  • obskuritz
    • Jul 2026
    Hi Colporteur, welcome to zabbix software monitoring community
    Could you share me the log from your Zabbix server? for more details
    it is located in:
    /var/log/zabbix/zabbix_server.log
      • 5004
      Port 443 here is kind of irrelevant. Frontend does check, if server is available (https://git.zabbix.com/projects/ZBX/...rpc.php#66-109). Make sure nginx is able to connect to 10051 port, where server is listening.
      • colporteur
        • Jul 2026
        After some AI help, I have http redirected to https on self-signed certificates
        Understanding the relationship of these three files:
        Configures Nginx to serve the Zabbix web interface: /etc/zabbix/nginx.conf
        Configures the Zabbix Server daemon: /etc/zabbix/zabbix_server.conf
        Configures the PHP web frontend: /usr/share/zabbix/ui/conf/zabbix.conf.php
        allowed me to configure the https support configuration like port numbers and pointers to the certificates and the correct passwords to get it working.
        • irontmp
          • Sep 2023
          • 100
          I have installed nginx and have it working on port 433 using the self-signed-certificates. I then installed php and it serves webpage on 443. I then installed mysql and finally zabbix. I can connect to the zabbix web interface console :443 but the error message at the bottom indicates Zabbix Server is not running:the information displayed may not be current.
          I am a new user to Zabbix with no experience at all. After evaluating a few products, I landed here. The goal is to replace the MikroTik Dude server with Zabbix. I even came across roll off dumpster rental while browsing other discussions, but what I really need is guidance on configuring HTTPS. If someone could share their knowledge or point me toward useful HTTPS configuration resources, I would really appreciate it.
          Since your Zabbix setup already worked on port 8080, I would not change the Zabbix configuration just to enable HTTPS. Let nginx handle the SSL connection on port 443 and continue passing requests to the Zabbix frontend through PHP. The “Zabbix Server is not running” message is more likely related to the Zabbix server service or its database connection than to your self signed certificate. Check that the Zabbix server service is running and that its database credentials are correct. Also double check that you are actually using port 443 rather than 433, since you mentioned both. If the server worked before switching nginx to HTTPS, comparing the old working nginx configuration with the new one should help identify what changed.
