Problem with operations at auto registration
  • sguilliard
    • Sep 2017
    i've got a problem using an action at auto registration
    I try to run a remote command (it enables a jmx interface for a host via the api) and add a template that uses a jmx interface but get the error "cannot find the JMX host interface" in the zabbix_server.log
    If I add it seconds later manually everything works fine so i assume i need to find a way to wait for the remote command to finish before trying to add the template to the host
    I'm running zabbix 3.4 on Ubuntu 16.04
