Database error with Zabbix 7.0.30 and mySQL
  • hrrapozo
    • Nov 2025
    • 33
    This morning (9/1/26) both my test and production systems which run Ubuntu 24.04.04 LTS, Zabbix 7.0.30 and mySQL gave a Database error when attempting to access their webpage (screen shot is below).
    Right now I am trying to shutdown the zabbix server (via sudo systemctl stop zabbix-server) but it is taking a while to do.
    When doing a apt list --upgradable on the production system it notes that there are 5 updates relating to mysql
    coreutils/noble-updates,noble-security 9.4-3ubuntu6.3 amd64 [upgradable from: 9.4-3ubuntu6.2]
    cpio/noble-updates,noble-security 2.15+dfsg-1ubuntu2.1 amd64 [upgradable from: 2.15+dfsg-1ubuntu2]
    diffutils/noble-updates,noble-security 1:3.10-1ubuntu0.1 amd64 [upgradable from: 1:3.10-1build1]
    libmysqlclient21/noble-updates,noble-security 8.0.46-0ubuntu0.24.04.4 amd64 [upgradable from: 8.0.46-0ubuntu0.24.04.3]
    libpython3.12-minimal/noble-updates 3.12.3-1ubuntu0.16 amd64 [upgradable from: 3.12.3-1ubuntu0.15]
    libpython3.12-stdlib/noble-updates 3.12.3-1ubuntu0.16 amd64 [upgradable from: 3.12.3-1ubuntu0.15]
    libpython3.12t64/noble-updates 3.12.3-1ubuntu0.16 amd64 [upgradable from: 3.12.3-1ubuntu0.15]
    libssh-4/noble-updates,noble-security 0.10.6-2ubuntu0.5 amd64 [upgradable from: 0.10.6-2ubuntu0.4]
    libudisks2-0/noble-updates,noble-security 2.10.1-6ubuntu1.5 amd64 [upgradable from: 2.10.1-6ubuntu1.3]
    mysql-client-8.0/noble-updates,noble-security 8.0.46-0ubuntu0.24.04.4 amd64 [upgradable from: 8.0.46-0ubuntu0.24.04.3]
    mysql-client-core-8.0/noble-updates,noble-security 8.0.46-0ubuntu0.24.04.4 amd64 [upgradable from: 8.0.46-0ubuntu0.24.04.3]
    mysql-server-8.0/noble-updates,noble-security 8.0.46-0ubuntu0.24.04.4 amd64 [upgradable from: 8.0.46-0ubuntu0.24.04.3]
    mysql-server-core-8.0/noble-updates,noble-security 8.0.46-0ubuntu0.24.04.4 amd64 [upgradable from: 8.0.46-0ubuntu0.24.04.3]
    mysql-server/noble-updates,noble-security 8.0.46-0ubuntu0.24.04.4 all [upgradable from: 8.0.46-0ubuntu0.24.04.3]
    python3.12/noble-updates 3.12.3-1ubuntu0.16 amd64 [upgradable from: 3.12.3-1ubuntu0.15]
    udisks2/noble-updates,noble-security 2.10.1-6ubuntu1.5 amd64 [upgradable from: 2.10.1-6ubuntu1.3]
    Anyway I am just wondering if anyone else is suffering from this same problem?
  • tim.mooney
    • Dec 2012
    • 1437
    Ubuntu defaults to auto-applying updates, at least for security-related updates. I don't know if updates are turned on for everything, or just for security; I don't run Ubuntu so I'm not certain.
    Security updates were released that impact mysql. You can see them in the list you show, along with other updates.
    Either the updates failed to apply (for some reason) or something else with the updates went wrong, because mysql was shut down as part of the update process that never happened. That's why you're seeing the database error. The system shut it down as part of automated updates, but didn't complete the automated updates.
    The zabbix_server basically requires a database of some type (in your case, mysql) at all times. It's still running, but it's not healthy. In addition, the service file that starts zabbix_server will wait a really long time for the database to be "ready". The developers did that for a reason and I'm certain it's a good one, but in situations like this, where the database goes away unexpectedly, it can make restarts difficult.
    If you can manually apply all the updates, do so. Then reboot. I think everything should come back once you've updated the database and it's willing to start up.
    • hrrapozo
      • Nov 2025
      • 33
      In the end I had to restart the system, which allowed the zabbix application to run again. I did stop the zabbix server application, applied the updates and then reboot the system.
      • irontmp
        • Sep 2023
        • 100
        Either the updates failed to apply for some reason or something else with the updates went wrong, because MySQL was shut down as part of the update process that never happened. I’d use a picker wheel to narrow down the possible causes, because that’s why you're seeing the database error. The system shut it down as part of automated updates, but didn't complete the automated updates.
        Since both the test and production Zabbix systems failed at the same time, I’d suspect a common dependency or recent update rather than two independent Zabbix problems. The MySQL packages being upgradable is worth investigating, but I wouldn’t assume the pending update caused the failure without checking the logs first. I’d look at journalctl -u mysql and the Zabbix server log, then verify that MySQL is running and accepting connections. If MySQL is healthy, check the Zabbix database credentials and connection errors next. Since you have a test system, I’d troubleshoot there first before changing anything on production.
