Zabbix queue backlog with IIS AppPool current queue size items
  • andrewkirwin
    • Sep 2026
    Zabbix Server: 7.0.17
    Zabbix Agent 2 (Windows): 7.0.30
    Client: Windows Server 2022 Standard
    Template: IIS by Zabbix Agent (7.0-3)
    Hi All,
    I am experiencing an issue with the IIS by Zabbix Agent AppPool current queue size item getting stuck in the queue when the AppPool is stopped, or running but unassigned.
    I have investigated the Zabbix Agent 2 logs on the client machine and believe I have found the culprit, but was wondering if anyone else has seen or been able to resolve this issue?
    got nil value, skipping sending of response
    I see this after the agent is queried for the AppPool current queue size of a stopped/unassigned IIS application on version 7.0.30 of the Windows client.
    Rolling back to version 7.0.12 I get the below...
    sending passive check response: '{"version":"7.0.12","variant":2,"data":[{value":null}]}' to 'PROXY-IP-REDACTED'
    Suggesting a change in logic between the versions, where the older version sends a "null" value and the newer version doesn't send anything.
    Sending nothing means the item sits in the queue on the server... waiting for a value... forever.
    Thanks in advance for you assistance,
    Andrew
