Normalizing printer supply names -
  • furicle
    • Feb 2026
    Zabbix 7.4 on Alma 9
    I'm monitoring a number of network printers using the Universal Printer template and snmp
    It works well, but different manufacturers have different names for their supplies. So when I try to build a dashboard for just the supplies, I end up with multiple entries like
    • "Remaining Black Toner Cartridge S/N:CRUM-123456789"
    • "Remaining Black Toner" and
    • "Remaining Black Cartridge"
    depending on manufacturer.
    I mucked around a bit and tried to put regex in preprocessing on the five item prototypes in the template of universal printer
    (?i)^(.*?)\s*(?:toner\s*)?(?:cartridge|module|s/n).*
    replace with
     \1 Toner
    but that doesn't seem to be working. Feels like I'm in the wrong spot?
    Where do I insert the regex to standardize things?
    • 5004
    / Delimiter must be escaped with `\`
    Not all of your examples match https://regex101.com/r/bk4Tuq/1
    But in general, item value preprocessing is the correct place to extract something from aqcuired value and modify it...
    • furicle
      • Feb 2026
      Thanks for the feedback, I've fixed escaping the \
      The 'remaining' from my example is in the item itself, so that's ok not to match.
      Still not working, even cartridge vs toner. Haven't figured out what I'm missing.
