need to exclude /sys/firmware/efi/efivars from vfs.fs.get
  • AlexeySaff
    • Aug 2021
    • 22
    Hi, on DELL/HP systems, calling vfs.fs.get provides 2 SMI interrupts at the idrac/ilo level, which dramatically increase osjitter. Is it possible somehow to completely exclude reading this partition? Applying it at the host level doesn't work, as it only filters it.
    • 5004
    I don't think you can do that.. vfs.fs.get does not have any options available, so it blindly just gathers all possible data...
    • AlexeySaff
      • Aug 2021
      • 22
      yes, I know. So I' trying to suggest to dev team about this. Is that is possible via the forum
        • 5004
        You can submit dev ideas to https://support.zabbix.com/browse/ZBXNEXT , you need to register,but it does not bring any "concequences".. you can also search exisitng ideas and upvote those you like...
