my Zabbix 3.2.8 stopped working last thursday and I can't make it run again. I do not know what happened - many hosts switched to "Zabbix agent is unreachable for 5 minutes" at the same time and no notifications have been sent (error "Timeout was reached: Operation timed out after 0 milliseconds with 0 out of 0 bytes received").
When I restart the zabbix-server service now, it runs for a few seconds and then exits - here's the zabbix_server.log with debug level 4. The terminating pollers, dying child process and then exit of the whole service are happening every single time.
OS is Ubuntu 16.04 LTS
Oct 02 10:37:20 zabbix systemd[1]: Starting Zabbix Server...
Oct 02 10:37:20 zabbix systemd[1]: zabbix-server.service: PID file /run/zabbix/zabbix_server.pid not readable (yet?) after start: No such file or directory
Oct 02 10:37:20 zabbix systemd[1]: Started Zabbix Server.
katja@zabbix:/etc/zabbix$ sudo tail -n 300 /var/log/zabbix/zabbix_server.log
2447:20171002:103721.140 get value from agent result: '0'
2447:20171002:103721.140 End of get_value_agent():SUCCEED
2447:20171002:103721.140 End of get_value():SUCCEED
2447:20171002:103721.140 In activate_host() hostid:10561 itemid:56121 type:0
2447:20171002:103721.140 End of activate_host()
2447:20171002:103721.140 End of get_values():1
2447:20171002:103721.140 In get_values()
2447:20171002:103721.140 In DCconfig_get_poller_items() poller_type:0
2447:20171002:103721.140 End of DCconfig_get_poller_items():1
2447:20171002:103721.140 In substitute_key_macros() data:'vmbix[vm.counter,{HOST.HOST},cpu.ready.summation]'
2447:20171002:103721.140 In substitute_simple_macros() data:'{HOST.HOST}'
2447:20171002:103721.140 End substitute_simple_macros() data:'4215695c-15c5-9334-a90c-d206d875431c'
2447:20171002:103721.140 End of substitute_key_macros():SUCCEED data:'vmbix[vm.counter,4215695c-15c5-9334-a90c-d206d875431c,cpu.ready.summation]'
2447:20171002:103721.140 In substitute_simple_macros() data:EMPTY
2447:20171002:103721.140 In get_value() key:'vmbix[vm.counter,{HOST.HOST},cpu.ready.summation]'
2447:20171002:103721.140 In get_value_simple() key_orig:'vmbix[vm.counter,{HOST.HOST},cpu.ready.summation]' addr:'AT1177.XXX'
2445:20171002:103721.141 Sending [service.info[VGAuthService,state]
2445:20171002:103721.143 get value from agent result: '0'
2445:20171002:103721.143 End of get_value_agent():SUCCEED
2445:20171002:103721.143 End of get_value():SUCCEED
2445:20171002:103721.143 In activate_host() hostid:10608 itemid:59841 type:0
2445:20171002:103721.143 End of activate_host()
2445:20171002:103721.143 End of get_values():1
2445:20171002:103721.143 In get_values()
2445:20171002:103721.143 In DCconfig_get_poller_items() poller_type:0
2445:20171002:103721.143 End of DCconfig_get_poller_items():1
2445:20171002:103721.143 In substitute_key_macros() data:'vm.memory.size[free]'
2445:20171002:103721.143 End of substitute_key_macros():SUCCEED data:'vm.memory.size[free]'
2445:20171002:103721.143 In substitute_simple_macros() data:'10050'
2445:20171002:103721.143 In get_value() key:'vm.memory.size[free]'
2445:20171002:103721.143 In get_value_agent() host:'4215d04b-80bf-5a04-3e58-3bd5ab729750' addr:'10.11.223.13' key:'vm.memory.size[free]' conn:'unencrypted'
2445:20171002:103721.144 Sending [vm.memory.size[free]
2445:20171002:103721.145 get value from agent result: '4063129600'
2445:20171002:103721.145 End of get_value_agent():SUCCEED
2445:20171002:103721.145 End of get_value():SUCCEED
2445:20171002:103721.145 In activate_host() hostid:10608 itemid:50601 type:0
2445:20171002:103721.145 End of activate_host()
2445:20171002:103721.145 End of get_values():1
2445:20171002:103721.145 In get_values()
2445:20171002:103721.145 In DCconfig_get_poller_items() poller_type:0
2445:20171002:103721.145 End of DCconfig_get_poller_items():1
2445:20171002:103721.145 In substitute_key_macros() data:'vmbix[vm.counter,{HOST.HOST},cpu.usagemhz.average,2,300]'
2445:20171002:103721.145 In substitute_simple_macros() data:'{HOST.HOST}'
2445:20171002:103721.145 End substitute_simple_macros() data:'42156053-8c81-9e75-5bdf-0ad32d7ee80b'
2445:20171002:103721.145 End of substitute_key_macros():SUCCEED data:'vmbix[vm.counter,42156053-8c81-9e75-5bdf-0ad32d7ee80b,cpu.usagemhz.average,2,300]'
2445:20171002:103721.145 In substitute_simple_macros() data:EMPTY
2445:20171002:103721.145 In get_value() key:'vmbix[vm.counter,{HOST.HOST},cpu.usagemhz.average,2,300]'
2445:20171002:103721.145 In get_value_simple() key_orig:'vmbix[vm.counter,{HOST.HOST},cpu.usagemhz.average,2,300]' addr:'AT1103.XXX'
2450:20171002:103721.156 __zbx_zbx_setproctitle() title:'trapper #1 [processing data]'
2450:20171002:103721.157 trapper got '{"request":"active checks","host":"4236d350-96e2-e18c-a722-2fe080cb983b"}'
2450:20171002:103721.157 In send_list_of_active_checks_json()
2450:20171002:103721.157 In is_ip4() ip:'10.222.201.160'
2450:20171002:103721.157 End of is_ip4():SUCCEED
2450:20171002:103721.157 In get_hostid_by_host() host:'4236d350-96e2-e18c-a722-2fe080cb983b'
2450:20171002:103721.157 query [txnlev:0] [select hostid,status,tls_accept,tls_issuer,tls_subject,tls_psk_identity from hosts where host='4236d350-96e2-e18c-a722-2fe080cb983b' and status in (0,1) and flags<>2 and proxy_hostid is null]
2450:20171002:103721.157 End of get_hostid_by_host():SUCCEED
2450:20171002:103721.157 query [txnlev:0] [select itemid from items where type=7 and flags<>2 and hostid=10516]
2450:20171002:103721.158 send_list_of_active_checks_json() sending [{"response":"success","data":[]}]
2450:20171002:103721.158 End of send_list_of_active_checks_json():SUCCEED
2450:20171002:103721.158 __zbx_zbx_setproctitle() title:'trapper #1 [processed data in 0.001307 sec, waiting for connection]'
*** stack smashing detected ***: /usr/sbin/zabbix_server: poller #3 [got 0 values in 0.000000 sec, getting values] terminated
*** stack smashing detected ***: /usr/sbin/zabbix_server: poller #5 [got 0 values in 0.000000 sec, getting values] terminated
2441:20171002:103721.623 One child process died (PID:2444,exitcode/signal:6). Exiting ...
2441:20171002:103721.623 zbx_on_exit() called
2442:20171002:103721.623 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2443:20171002:103721.624 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2449:20171002:103721.625 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2455:20171002:103721.627 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2456:20171002:103721.631 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2457:20171002:103721.632 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2458:20171002:103721.638 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2459:20171002:103721.647 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2461:20171002:103721.648 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2462:20171002:103721.649 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2463:20171002:103721.655 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2464:20171002:103721.659 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2465:20171002:103721.660 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2466:20171002:103721.667 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2478:20171002:103721.668 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2479:20171002:103721.671 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2451:20171002:103721.675 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2452:20171002:103721.678 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2454:20171002:103721.681 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2453:20171002:103721.682 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2450:20171002:103721.700 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2460:20171002:103721.703 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2447:20171002:103721.713 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2445:20171002:103721.723 Got signal [signal:15(SIGTERM),sender_pid:2441,sender_uid:112,reason:0]. Exiting ...
2441:20171002:103723.623 In DBconnect() flag:1
2441:20171002:103723.624 End of DBconnect():0
2441:20171002:103723.624 In free_database_cache()
2441:20171002:103723.624 In DCsync_all()
2441:20171002:103723.624 In DCsync_history() history_num:36
2441:20171002:103723.625 syncing history data...
2441:20171002:103723.625 query [txnlev:1] [begin;]
2441:20171002:103723.625 In DCmass_update_items()
2441:20171002:103723.625 End of DCmass_update_items()
2441:20171002:103723.625 In DCmass_add_history()
2441:20171002:103723.626 query [txnlev:1] [insert into history (itemid,clock,ns,value) values (49521,1506933441,60255166,0.000000),(56001,1506933441,84370595,18.259513),(47421,1506933441,101511669,149436.506375);
2441:20171002:103723.654 query [txnlev:1] [insert into history_uint (itemid,clock,ns,value) values (43701,1506933441,39777347,0),(54681,1506933441,53349849,0),(62061,1506933441,63622380,6),(57561,1506933441,79658010,0),(57441,1506933441,81298172,0),(58821,1506933441,82991097,0),(55941,1506933441,83617502,0),(52881,1506933441,86826187,0),(55641,1506933441,97143319,0),(57081,1506933441,99750282,0),(57141,1506933441,100102200,75018240),(56481,1506933441,102535315,0),(59361,1506933441,107334121,0),(59061,1506933441,118791668,0),(56781,1506933441,126386949,0),(45321,1506933441,129657761,19419325),(59841,1506933441,143329826,0),(50601,1506933441,145267461,4063129600);
2441:20171002:103723.904 In zbx_vc_add_value() itemid:43701 value_type:3 timestamp:1506933441.39777347
2441:20171002:103723.904 End of zbx_vc_add_value():FAIL
2441:20171002:103723.904 In zbx_vc_add_value() itemid:54681 value_type:3 timestamp:1506933441.53349849
2441:20171002:103723.904 In zbx_vc_add_value() itemid:49521 value_type:0 timestamp:1506933441.60255166
2441:20171002:103723.904 In zbx_vc_add_value() itemid:62061 value_type:3 timestamp:1506933441.63622380
2441:20171002:103723.904 In zbx_vc_add_value() itemid:57561 value_type:3 timestamp:1506933441.79658010
2441:20171002:103723.904 In zbx_vc_add_value() itemid:57441 value_type:3 timestamp:1506933441.81298172
2441:20171002:103723.904 In zbx_vc_add_value() itemid:58821 value_type:3 timestamp:1506933441.82991097
2441:20171002:103723.904 In zbx_vc_add_value() itemid:55941 value_type:3 timestamp:1506933441.83617502
2441:20171002:103723.904 In zbx_vc_add_value() itemid:56001 value_type:0 timestamp:1506933441.84370595
2441:20171002:103723.904 In zbx_vc_add_value() itemid:52881 value_type:3 timestamp:1506933441.86826187
2441:20171002:103723.904 In zbx_vc_add_value() itemid:55641 value_type:3 timestamp:1506933441.97143319
2441:20171002:103723.904 In zbx_vc_add_value() itemid:57081 value_type:3 timestamp:1506933441.99750282
2441:20171002:103723.904 In zbx_vc_add_value() itemid:57141 value_type:3 timestamp:1506933441.100102200
2441:20171002:103723.904 In zbx_vc_add_value() itemid:47421 value_type:0 timestamp:1506933441.101511669
2441:20171002:103723.904 In zbx_vc_add_value() itemid:56481 value_type:3 timestamp:1506933441.102535315
2441:20171002:103723.904 In zbx_vc_add_value() itemid:59361 value_type:3 timestamp:1506933441.107334121
2441:20171002:103723.904 In zbx_vc_add_value() itemid:59061 value_type:3 timestamp:1506933441.118791668
2441:20171002:103723.904 In zbx_vc_add_value() itemid:56781 value_type:3 timestamp:1506933441.126386949
2441:20171002:103723.904 In zbx_vc_add_value() itemid:45321 value_type:3 timestamp:1506933441.129657761
2441:20171002:103723.904 In zbx_vc_add_value() itemid:59841 value_type:3 timestamp:1506933441.143329826
2441:20171002:103723.904 In zbx_vc_add_value() itemid:50601 value_type:3 timestamp:1506933441.145267461
2441:20171002:103723.904 End of DCmass_add_history()
2441:20171002:103723.904 In DCmass_update_triggers()
2441:20171002:103723.904 In zbx_link_triggers_with_functions() trigger_order_num:5
2441:20171002:103723.904 In substitute_simple_macros() data:'{17012}<0'
2441:20171002:103723.904 End substitute_simple_macros() data:'{17012}<0'
2441:20171002:103723.905 In substitute_simple_macros() data:'{18446}<10000'
2441:20171002:103723.905 End substitute_simple_macros() data:'{18446}<10000'
2441:20171002:103723.905 In substitute_simple_macros() data:'{20868}<10 and {20868}>5'
2441:20171002:103723.905 End substitute_simple_macros() data:'{20868}<10 and {20868}>5'
2441:20171002:103723.905 In substitute_simple_macros() data:'{25388}<5 and {25388}>1'
2441:20171002:103723.905 End substitute_simple_macros() data:'{25388}<5 and {25388}>1'
2441:20171002:103723.905 In substitute_simple_macros() data:'{25390}<1'
2441:20171002:103723.905 End substitute_simple_macros() data:'{25390}<1'
2441:20171002:103723.905 End of zbx_link_triggers_with_functions() triggers_func_pos_num:5
2441:20171002:103723.905 In evaluate_expressions() tr_num:5
2441:20171002:103723.905 In substitute_simple_macros() data:'{17012}<0'
2441:20171002:103723.905 End substitute_simple_macros() data:'{17012}<0'
2441:20171002:103723.905 In substitute_functions()
2441:20171002:103723.905 In zbx_extract_functionids() tr_num:5
2441:20171002:103723.905 End of zbx_extract_functionids() functionids_num:5
2441:20171002:103723.905 In zbx_populate_function_items() functionids_num:5
2441:20171002:103723.905 End of zbx_populate_function_items() ifuncs_num:5
2441:20171002:103723.905 In zbx_evaluate_item_functions() funcs_num:3
2441:20171002:103723.905 In evaluate_function() function:'4215a1fb-6275-d439-9a0e-dd460bd5c0b4:vfs.fs.size[C:,pfree].last(0)'
2441:20171002:103723.905 In evaluate_LAST()
2441:20171002:103723.905 In get_function_parameter_int() parameters:'0' Nparam:1
2441:20171002:103723.905 In substitute_simple_macros() data:'0'
2441:20171002:103723.905 get_function_parameter_int() type:sec value:0
2441:20171002:103723.905 End of get_function_parameter_int():SUCCEED
2441:20171002:103723.905 In zbx_vc_get_value_range() itemid:56001 value_type:0 seconds:0 count:1 timestamp:1506933441
2441:20171002:103723.905 query [txnlev:1] [select clock,ns,value from history where itemid=56001 and clock<=1506933441 and clock>1506929841 order by clock desc limit 1]
2441:20171002:103723.908 query [txnlev:1] [select clock,ns,value from history where itemid=56001 and clock=1506933441]
2441:20171002:103723.909 query [txnlev:1] [select clock,ns,value from history where itemid=56001 and clock>1506933441 and clock<=1506933443]
2441:20171002:103723.909 End of zbx_vc_get_value_range():SUCCEED count:1 cached:1
2441:20171002:103723.909 End of evaluate_LAST():SUCCEED
2441:20171002:103723.909 End of evaluate_function():SUCCEED value:'18.2595'
2441:20171002:103723.909 In evaluate_function() function:'4215a1c2-35a0-7ab5-7eb3-a459557c48aa:system.uptime.change(0)'
2441:20171002:103723.909 In evaluate_CHANGE()
2441:20171002:103723.909 In zbx_vc_get_value_range() itemid:45321 value_type:3 seconds:0 count:2 timestamp:1506933441
2441:20171002:103723.909 query [txnlev:1] [select clock,ns,value from history_uint where itemid=45321 and clock<=1506933441 and clock>1506929841 order by clock desc limit 2]
2441:20171002:103723.917 query [txnlev:1] [select clock,ns,value from history_uint where itemid=45321 and clock<=1506929841 and clock>1506843441 order by clock desc limit 1]
2441:20171002:103723.917 query [txnlev:1] [select clock,ns,value from history_uint where itemid=45321 and clock<=1506843441 and clock>1506238641 order by clock desc limit 1]
2441:20171002:103723.929 query [txnlev:1] [select clock,ns,value from history_uint where itemid=45321 and clock=1506593841]
2441:20171002:103723.930 query [txnlev:1] [select clock,ns,value from history_uint where itemid=45321 and clock>1506933441 and clock<=1506933443]
2441:20171002:103723.931 End of zbx_vc_get_value_range():SUCCEED count:2 cached:1
2441:20171002:103723.931 End of evaluate_CHANGE():SUCCEED
2441:20171002:103723.931 End of evaluate_function():SUCCEED value:'339600'
2441:20171002:103723.931 In evaluate_function() function:'4215d04b-80bf-5a04-3e58-3bd5ab729750:vm.memory.size[free].last(0)'
2441:20171002:103723.931 In evaluate_LAST()
2441:20171002:103723.931 In get_function_parameter_int() parameters:'0' Nparam:1
2441:20171002:103723.931 In substitute_simple_macros() data:'0'
2441:20171002:103723.931 get_function_parameter_int() type:sec value:0
2441:20171002:103723.931 End of get_function_parameter_int():SUCCEED
2441:20171002:103723.932 In zbx_vc_get_value_range() itemid:50601 value_type:3 seconds:0 count:1 timestamp:1506933441
2441:20171002:103723.932 query [txnlev:1] [select clock,ns,value from history_uint where itemid=50601 and clock<=1506933441 and clock>1506929841 order by clock desc limit 1]
2441:20171002:103723.934 query [txnlev:1] [select clock,ns,value from history_uint where itemid=50601 and clock=1506933441]
2441:20171002:103723.935 query [txnlev:1] [select clock,ns,value from history_uint where itemid=50601 and clock>1506933441 and clock<=1506933443]
2441:20171002:103723.935 End of zbx_vc_get_value_range():SUCCEED count:1 cached:1
2441:20171002:103723.935 End of evaluate_LAST():SUCCEED
2441:20171002:103723.935 End of evaluate_function():SUCCEED value:'4063129600'
2441:20171002:103723.935 End of zbx_evaluate_item_functions()
2441:20171002:103723.935 In zbx_substitute_functions_results() ifuncs_num:5 tr_num:5
2441:20171002:103723.935 zbx_substitute_functions_results() expression[0]:'{17012}<0' => '339600<0'
2441:20171002:103723.935 zbx_substitute_functions_results() expression[1]:'{18446}<10000' => '4063129600<10000'
2441:20171002:103723.935 zbx_substitute_functions_results() expression[2]:'{20868}<10 and {20868}>5' => '18.2595<10 and 18.2595>5'
2441:20171002:103723.936 zbx_substitute_functions_results() expression[3]:'{25388}<5 and {25388}>1' => '18.2595<5 and 18.2595>1'
2441:20171002:103723.936 zbx_substitute_functions_results() expression[4]:'{25390}<1' => '18.2595<1'
2441:20171002:103723.936 End of zbx_substitute_functions_results()
2441:20171002:103723.936 End of substitute_functions()
2441:20171002:103723.936 In evaluate() expression:'339600<0'
2441:20171002:103723.936 End of evaluate() value:0.000000
2441:20171002:103723.936 In evaluate() expression:'4063129600<10000'
2441:20171002:103723.936 In evaluate() expression:'18.2595<10 and 18.2595>5'
2441:20171002:103723.936 In evaluate() expression:'18.2595<5 and 18.2595>1'
2441:20171002:103723.936 In evaluate() expression:'18.2595<1'
2441:20171002:103723.936 End of evaluate_expressions()
2441:20171002:103723.936 In zbx_process_triggers() values_num:5
2441:20171002:103723.936 In zbx_process_trigger() triggerid:16628 value:0(0) new_value:3
2441:20171002:103723.936 End of zbx_process_trigger():FAIL flags:0
2441:20171002:103723.936 In zbx_process_trigger() triggerid:17819 value:0(0) new_value:3
2441:20171002:103723.936 In zbx_process_trigger() triggerid:19907 value:0(0) new_value:3
2441:20171002:103723.936 In zbx_process_trigger() triggerid:23901 value:0(0) new_value:3
2441:20171002:103723.936 In zbx_process_trigger() triggerid:23903 value:0(0) new_value:3
2441:20171002:103723.936 End of zbx_process_triggers()
2441:20171002:103723.936 End of DCmass_update_triggers()
2441:20171002:103723.936 In DCmass_update_trends()
2441:20171002:103723.936 End of DCmass_update_trends()
2441:20171002:103723.936 In process_trigger_events() events_num:0
2441:20171002:103723.936 End of process_trigger_events() processed:0
2441:20171002:103723.936 query [txnlev:1] [commit;]
2441:20171002:103723.944 In flush_correlated_events() events_num:0
2441:20171002:103723.944 End of flush_correlated_events() events_num:0
2441:20171002:103723.944 syncing history data done
2441:20171002:103723.944 In DCsync_trends() trends_num:0
2441:20171002:103723.944 syncing trend data...
2441:20171002:103723.944 query [txnlev:1] [begin;]
2441:20171002:103723.944 In DCflush_trends() trends_num:21
2441:20171002:103723.944 query [txnlev:1] [select distinct itemid from trends where clock>=1506931200 and itemid in (47421,49521,56001)]
2441:20171002:103723.981 query [txnlev:1] [insert into trends (itemid,clock,num,value_min,value_avg,value_max) values (56001,1506931200,1,18.259513,18.259513,18.259513),(47421,1506931200,1,149436.506375,149436.506375,149436.506375),(49521,1506931200,1,0.000000,0.000000,0.000000);
2441:20171002:103723.982 End of DCflush_trends()
2441:20171002:103723.982 In DCflush_trends() trends_num:18
2441:20171002:103723.982 query [txnlev:1] [select distinct itemid from trends_uint where clock>=1506931200 and itemid in (43701,45321,50601,52881,54681,55641,55941,56481,56781,57081,57141,57441,57561,58821,59061,59361,59841,62061)]
2441:20171002:103724.067 query [txnlev:1] [insert into trends_uint (itemid,clock,num,value_min,value_avg,value_max) values (45321,1506931200,1,19419325,19419325,19419325),(56781,1506931200,1,0,0,0),(50601,1506931200,1,4063129600,4063129600,4063129600),(59061,1506931200,1,0,0,0),(55941,1506931200,1,0,0,0),(57081,1506931200,1,0,0,0),(55641,1506931200,1,0,0,0),(56481,1506931200,1,0,0,0),(57561,1506931200,1,0,0,0),(62061,1506931200,1,6,6,6),(54681,1506931200,1,0,0,0),(52881,1506931200,1,0,0,0),(58821,1506931200,1,0,0,0),(57441,1506931200,1,0,0,0),(43701,1506931200,1,0,0,0),(59361,1506931200,1,0,0,0),(59841,1506931200,1,0,0,0),(57141,1506931200,1,75018240,75018240,75018240);
2441:20171002:103724.068 End of DCflush_trends()
2441:20171002:103724.068 query [txnlev:1] [commit;]
2441:20171002:103724.076 syncing trend data done
2441:20171002:103724.076 End of DCsync_trends()
2441:20171002:103724.076 End of DCsync_all()
2441:20171002:103724.076 In zbx_mem_destroy() descr:'history cache'
2441:20171002:103724.076 End of zbx_mem_destroy()
2441:20171002:103724.076 In zbx_mem_destroy() descr:'history index cache'
2441:20171002:103724.076 In zbx_mem_destroy() descr:'trend cache'
2441:20171002:103724.076 End of free_database_cache()
2441:20171002:103724.076 In free_configuration_cache()
2441:20171002:103724.076 In zbx_mem_destroy() descr:'configuration cache'
2441:20171002:103724.076 In zbx_strpool_destroy()
2441:20171002:103724.076 In zbx_mem_destroy() descr:'string pool'
2441:20171002:103724.076 End of zbx_strpool_destroy()
2441:20171002:103724.076 End of free_configuration_cache()
2441:20171002:103724.076 In zbx_vc_destroy()
2441:20171002:103724.076 In zbx_mem_destroy() descr:'value cache size'
2441:20171002:103724.076 End of zbx_vc_destroy()
2441:20171002:103724.076 In zbx_free_ipmi_handler()
2441:20171002:103724.076 End of zbx_free_ipmi_handler()
2441:20171002:103724.076 In free_selfmon_collector() collector:0x7fb6c1ce9000
2441:20171002:103724.077 End of free_selfmon_collector()
2441:20171002:103724.077 In zbx_unload_modules()
2441:20171002:103724.077 End of zbx_unload_modules()
2441:20171002:103724.077 Zabbix Server stopped. Zabbix 3.2.8 (revision 72884).
