Kevin Rodrigues Sometimes you just have to get a bit creative. You could pull the information through the API, including the host relations, or build a Grafana dashboard that queries the database directly. That way you can search by host or filter by template. There's usually a way to solve it if you're willing to look for one.
Can this work?
