We're running Zabbix version 2.4.8 (I know it's old, we're testing and planning the upgrade to 3.4 at the moment).
We have issues with a few of our triggers. The one that's mostly causing problems is monitoring the queue length and fires when the queue get's too long. The item is defined as follows:
It's correctly collecting data:
As you can see in the screenshot during the night the threshold for the trigger was reached 3 times and the trigger also fired accordingly, see Event-history:
Now the problem, as you can see, is that the trigger didn't fall back to the OK-State after the last status change at about 5:22 AM this morning.
We do occasionally have the same problem with other hostss that are monitored by one of our zabbix-proxies. Zabbix says the host is unavailable by ICMP but we can pin the host from the zabbix-proxy without any problem, and the ICMP-item that collects the data also says that the host is reachable, but the trigger never goes back in the OK state. We found a workaround for this problem by changing the IP-address of the host to a random IP which does not exist and then change it back later. But this is certainly no ideal solution.
Does anybody have any expericences with this problem?
