Zabbix execute external script timeout
  • bernaldopenas
    • Oct 2017
    • 13
    Hi:
    I having a timeout problem with an external check, when i execute in terminal the script i get:
    real 0m1.076s
    user 0m0.000s
    sys 0m0.024s
    I have a zabbix 3.2.7 and i have set the timeout paramenter in config to 6.
    ¿Can someone helpme with this issue?
  • kaspars.mednis
    • Oct 2017
    • 349
    Hello !
    Have you tried to execute this script from zabbix user ?
    it may be some permission issue
    Best regards,
    Kaspars
    • bernaldopenas
      • Oct 2017
      • 13
      Thanks kaspars!!! ... you're right ... i execute the script with zabbix and it's a problem with the RSA key in a ssh that i execute in the script, this connection needs verification ... anyway thanks for the idea ... i was totally bloked ... now it's working correctly.
