I am using a modified trigger for the Windows by Zabbix Agent template.
The
trigger has the following Event Name:
On Zabbix 7.0, this worked without issues, showing the VM total memory.
On Zabbix 8.0, after updating the templates, the event above shows up as:
The item key is correct, the item itself has data. It really is only an issue in the Event Name.
The
Windows: High memory utilization
Windows: High memory utilization of {{?last(//vm.memory.size[pused])}.fmtnum(1)}% from total {{?last(//vm.memory.size[total])/1024/1024/1024}.fmtnum(1)}GB (>{$MEMORY.UTIL.MAX}% for 5m)
Windows: High memory utilization of 97.2% from total *UNKNOWN*GB (>90% for 5m)
