Crach on zabbix Database
  • omid1979
    • Nov 2016
    • 33
    hi all
    in this day we have problem on our zabbix server , on wall view we lost map and when I check zabbix server's found that zabbix server are stoped ,
    during troubleshooting check I see that mariadb sql is crached with the error below ,
    I am trying upgrade mariadb to last version using yum update mariadb ,
    after update steel have a problem
    p.s : in another time I try to recover my clone backup of our server but after one day mysql crached again ,
    anyone can help me what happen to our server ?
    Server : centos 7.3 ( upgrade to 7.4 )
    Zabbix server : 3.4
    PHP Code:
    ###/var/log/mariadb/mariadb.log
    171016 08:00:10 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
    171016  8
    :00:10 [Note] /usr/libexec/mysqld (mysqld 5.5.56-MariaDB) starting as process 38260 ...
    171016  8:00:10 InnoDB: The InnoDB memory heap is disabled
    171016  8
    :00:10 InnoDB: Mutexes and rw_locks use GCC atomic builtins
    171016  8
    :00:10 InnoDB: Compressed tables use zlib 1.2.7
    171016  8
    :00:10 InnoDB: Using Linux native AIO
    171016  8
    :00:10 InnoDB: Initializing buffer pool, size = 128.0M
    171016  8
    :00:10 InnoDB: Completed initialization of buffer pool
    171016  8
    :00:10 InnoDB: highest supported file format is Barracuda.
    171016  8:00:10  InnoDB: Starting crash recovery from checkpoint LSN=860866004661
    InnoDB
    : Restoring possible half-written data pages from the doublewrite buffer...
    171016  8:00:10  InnoDB: Starting final batch to recover 1921 pages from redo log
    171016  8
    :00:11  InnoDB: Waiting for the background threads to start
    171016  8
    :00:12  InnoDB: Assertion failure in thread 139977639614208 in file btr0btr.c line 3380
    InnoDB
    : Failing assertion: btr_page_get_next(merge_page, mtr) == buf_block_get_page_no(block)
    InnoDB: We intentionally generate a memory trap.
    InnoDB: Submit a detailed bug report to http://bugs.mysql.com.
    InnoDB: If you get repeated assertion failures or crashes, even
    InnoDB
    : immediately after the mysqld startup, there may be
    InnoDB
    : corruption in the InnoDB tablespace. Please refer to
    InnoDB
    : http://dev.mysql.com/doc/refman/5.5/en/forcing-innodb-recovery.html
    InnoDB: about forcing recovery.
    171016  8:00:12 [ERROR] mysqld got signal 6 ;
    This could be because you hit a bug. It is also possible that this binary
    or one of the libraries it was linked against is corrupt, improperly built,
    or
    misconfigured. This error can also be caused by malfunctioning hardware.
    To report this bug, see http://kb.askmonty.org/en/reporting-bugs
    We will try our best to scrape up some info that will hopefully help
    diagnose the problem
    , but since we have already crashed,
    something is definitely wrong and this may fail.
    Server version: 5.5.56-MariaDB
    key_buffer_size
    =134217728
    read_buffer_size
    =131072
    max_used_connections
    =0
    max_threads
    =153
    thread_count
    =0
    It is possible that mysqld could
    use up to
    key_buffer_size
    + (read_buffer_size + sort_buffer_size)*max_threads = 466711 K  bytes of memory
    Hope that
    's ok; if not, decrease some variables in the equation.
    PHP Code:
    InnoDB: Starting crash recovery.
    InnoDB: Reading tablespace information from the .ibd files...
    InnoDB: Restoring possible half-written data pages from the doublewrite
    InnoDB
    : buffer...
    InnoDB: Doing recovery: scanned up to log sequence number 104797810688
    InnoDB
    : Doing recovery: scanned up to log sequence number 104798046742
    InnoDB
    : 1 transaction(s) which must be rolled back or cleaned up
    InnoDB
    : in total 53044165 row operations to undo
    InnoDB
    : Trx id counter is 3558500
    170301 11
    :28:58  InnoDB: Starting an apply batch of log records to the database...
    InnoDB: Progress in percents: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
    InnoDB
    : Apply batch completed
    InnoDB
    : Starting in background the rollback of uncommitted transactions
    170301 11
    :29:00  InnoDB: Rolling back trx with id 3546DD4, 53044165 rows to undo
    InnoDB
    : Progress in percents: 1170301 11:29:00  InnoDB: Waiting for the background threads to start
    170301 11
    :29:01 Percona XtraDB (http://www.percona.com) 5.5.49-MariaDB-38.0 started; log sequence number 104798046742
    170301 11:29:01 [Note] Plugin 'FEEDBACK' is disabled.
    170301 11:29:01 [Note] Server socket created on IP: '0.0.0.0'.
    170301 11:29:01 [Note] Event Scheduler: Loaded 0 events
    170301 11
    :29:01 [Note] /usr/libexec/mysqld: ready for connections.
    Version: '5.5.52-MariaDB'  socket: '/var/lib/mysql/mysql.sock'  port: 3306  MariaDB Server
     2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100
    InnoDB
    : Rolling back of trx id 3546DD4 completed
    170301 12
    :02:04  InnoDB: Rollback of non-prepared transactions completed
    170928 10
    :12:24 [Note] /usr/libexec/mysqld: Normal shutdown
    170928 10
    :12:24 [Note] Event Scheduler: Purging the queue. 0 events
    170928 10
    :12:24  InnoDB: Starting shutdown...
    170928 10:12:24  InnoDB: Waiting for 201 pages to be flushed
    170928 10
    :12:25  InnoDB: Shutdown completed; log sequence number 832554350725
    170928 10
    :12:25 [Note] /usr/libexec/mysqld: Shutdown complete
    170928 10
    :12:26 mysqld_safe mysqld from pid file /var/run/mariadb/mariadb.pid ended
    170928 10
    :49:48 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
    170928 10
    :49:49 [Note] /usr/libexec/mysqld (mysqld 5.5.52-MariaDB) starting as process 1351 ...
    170928 10:49:49 InnoDB: The InnoDB memory heap is disabled
    170928 10
    :49:49 InnoDB: Mutexes and rw_locks use GCC atomic builtins
    170928 10
    :49:49 InnoDB: Compressed tables use zlib 1.2.7
    170928 10
    :49:49 InnoDB: Using Linux native AIO
    170928 10
    :49:49 InnoDB: Initializing buffer pool, size = 128.0M
    170928 10
    :49:49 InnoDB: Completed initialization of buffer pool
    170928 10
    :49:49 InnoDB: highest supported file format is Barracuda.
    170928 10:49:51  InnoDB: Waiting for the background threads to start
    170928 10
    :49:52 Percona XtraDB (http://www.percona.com) 5.5.49-MariaDB-38.0 started; log sequence number 832554350725
    170928 10:49:52 [Note] Plugin 'FEEDBACK' is disabled.
