Hi all,
Wondering if someone can help.
I want to create a graph in Zabbix 3.2 using data collected from an MySQL query.
I've created a Userparameter in the zabbix_agentd.conf file and if I run a zabbix_get -s IP -k mysql.query I get the correct numerical value returned on my Zabbix server.
What I can't seem to figure out is how to get the results of that zabbix_get command into Zabbix and then put the results into a Graph.
I've tried creating an item and running the zabbix_get command but it keeps saying I've using the incorrect syntax.
The other idea I had was the setup the command in a script, put it in the externalscript folder but I'm not sure that would work.
What is the best way for me to do this?
Thanks in advance
Thanks in advance
