Trouble with Discovery rules
  • aft2d
    • Oct 2017
    Hey Guys,
    We've deployed docker on all of our host systems some days ago. Unfortunately docker mounts the disk in a different path again (/var/lib/docker/overlay2, /var/lib/docker/plugins)
    Zabbix finds these mounts with it's low level discovery and monitors them.
    To prevent zabbix from doing that I've created a global regular expression:
    Then I've added this global regular expression to the filter rule for the mounted file system discovery:
    So far so good.
    The mounted file system discovery is part of a template which is linked to several host groups. These groups have hosts.
    After some days troubleshooting why my filter does not work I discovered that the hosts don't use my updated filter.
    This is the setting of one of my hosts which uses the template with the updated filter.
    Here I see that it does not update.
    Long story short, I don't know why my changes to the discovery rules of the template aren't applied to the hosts.
    I've found some topics that say, that I have to clone the template and readd it.
    Basically I don't know if I did that correct, anyway it did not work
    I'm using Zabbix 3.4.3 on Ubuntu 16.04 Xenial LTS
    Thanks for help.
  • allexpetrov
    • May 2017
    • 361
    Sorry but I've lost the point.
    So you have few levels of items - host items and template items. There is some options which can be overridden on the host level.
    If you want to change the Template - best practice is to Clone the template with your custom naming and then edit the items. I've understood that you want to customize the regex for the Low-Level Discovery.
    Then I would suggest you to use Global regular expressions. Go to Administration -> General -> Find regular expressions in the drop-down menu and add your custom regular expression. Then if you want to refer to the Global regex - use @ symbol before its name.
    Then go yo the Configuration -> Templates , find the particular template you want to edit, perform full clone, go to your discovery and edit the discovery. Then perform unlink and clear to delet template from host and attach the new one.
    Hope it helps.
    Regards,
    Alex!
    • aft2d
      • Oct 2017
      Hi Alex,
      thanks for your response.
      That's exactly what I did, but the filter in the host configuration itself does not update.
      That's the configuration of the cloned/updated template:
      Templates > My Template > Discovery Rules > Mounted Filesystem Discovery > Filters
      And that's the configuration of the host:
      Hosts > My Host > Discovery Rules > Mounted Filesystem Discovery > Filters
      • kaspars.mednis
        • Oct 2017
        • 349
        Can you post your both expressions
        @Ignored Mounth Paths
        @File systems for discovery
        Regards,
        Kaspars
