regexp
  • SchylgeICT
    • Oct 2017
    • 33
    regexp
    Struggling with regular expressions.
    I want some windows services not auto discovered. The current regular exp is:
    ^(isaHelperSvc|gpsvc|MapsBroker|Net Driver HPZ12|Pml Driver HPZ12|SkypeUpdate|WbioSrvc|sppsvc|MMCSS|gupdate|Sy smonLog|clr_optimization_v2.0.50727_32|clr_optimiz ation_v4.0.30319_32)$
    I want, for example, the WpnUserService_123456 in this list. The number behind the service name is variable per workstation. How to I handle this?
  • SchylgeICT
    • Oct 2017
    • 33
    Think i got it by creating a second rule:
    ^\A(WpnUserService|OneSyncSvc|CDPUserSvc)
    • madeiranit
      • Oct 2017
      Where
      Hi SchylgeICT!
      Where did you created this rule?
      • SchylgeICT
        • Oct 2017
        • 33
        In administration->general-> select regular expression and create a second rule at "Windows service names for discovery"
        • madeiranit
          • Oct 2017
          With Result is TRUE?
          • SchylgeICT
            • Oct 2017
            • 33
            i think i attached a screen to this post.. edit: yes i did
            • madeiranit
              • Oct 2017
              Hi SchylgeICT,
              Thank you for your prompt response.
              But still showing Problems related to OneSyncSvc_, WpnUserService_ and CDPUserSvc_. Attached image with the errors.
              Could you help me?
              These are the configuration for Windows service names for discovery:
              1 » ^\A(WpnUserService|OneSyncSvc|CDPUserSvc)$ [Result is FALSE]
              2 » ^(MMCSS|gupdate|SysmonLog|clr_optimization_v2.0.50 727_32|clr_optimization_v4.0.30319_32)$ [Result is FALSE]
              • SchylgeICT
                • Oct 2017
                • 33
                I think your hosts services were allready disovered? Delete the host and reinsert it again. Are of that helps.
                • SchylgeICT
                  • Oct 2017
                  • 33
                  BTW, you might want to check if "Keep lost resources period" is still set to the default 30 days under templates--> windows template-->discovery-> service discovery rule.
