Zabbix runs but it doesn't seem to do anything...
  • mohamed_al_gad
    • Jan 2007
    Hello everybody,
    I'm quite new to Zabbix, I'm testing it, the goal is to replace our Nagios, but it seems that there is a problem...
    Problem :
    In Reports->Status of ZABBIX:
    - all my hosts are "monitored" except templates
    - all my items are "monitored" none are trapped
    - all my triggers are "enabled" and "unknown"
    In Monitoring->Latest data :
    for each row, i got : Last check, Last value, Change are "empty" (" - ")
    In Monitoring->Queue : all my items are in the "More than 5 minutes" column
    In Monitoring->Triggers : all triggers's status are "unknown" and last value is 01 Jan 01:00:00
    In Monitoring->Graphs : all graphs are displayed, but no data is showed on the down-left location.
    I don't understand, it is like if zabbix wasn't doing anything, just like waiting for me to say "GO GO GO Check them out".
    I use different items, such as icmpping, windows agents based, snmp, but none of them give me any value. For Windows Agents's host, I used the Windows_t template.
    I tried to restart services(zabbix, agents, apache), reboot(server & client).
    Another probable cause : When I start to zabbix service, I got the following messge :
    dev:/usr/local/zabbix/bin # /etc/init.d/zabbix_server start
    Starting zabbix_server done
    dev:/usr/local/zabbix/bin # /usr/local/zabbix/bin/zabbix_server: symbol lookup error: /usr/lib/libnetsnmp.so.5: undefined symbol: RAND_bytes
    I've made a lot of searches, but I didn't find someone that have the same issue, maybe someone could help me a bit, please ?
    Thanks in advance
    [EDIT] zabbix version 1.1.4
  • James Wells
    • Jun 2005
    • 664
    Greetings,
    First thing I would recommend is rebuilding the Zabbix server. Right off the bat, it sounds like you are missing a couple critical libraries, ie net-snmp.
    Unofficial Zabbix Developer
    • mohamed_al_gad
      • Jan 2007
      Okay, James Wells, thanks for the answer.
      I'll try to recompile, but I didn't noticed problems during my last compile, isn't that strange that the problem is encountered only at server's startup ?
      • dsipe
        • Oct 2006
        • 184
        what's your linux server ?
