Zabbix Version 1.1.5 - Can not add host names with a dash
  • Palmertree
    • Sep 2005
    • 746
    Is anyone else experiencing this issue in version 1.1.5. If you try and add a host name with a dash "-", I get an error saying that it is not allowed but it's showen in the allowed list. I used dashes plenty of times before in the hostname.
    I get this message:
    [ERROR:Cannot update host]
    Hostname should contain '0-9a-zA-Z_.-$' characters only
    Host I am trying to add is Computer-Test
  • Palmertree
    • Sep 2005
    • 746
    Compared the hosts.inc.php to a Zabbix version 1.1.4 and I found that the line below was different:
    Version 1.1.5:
    function db_save_host($host,$port,$status,$useip,$ip,$templ ateid,$hostid=NULL)
    if (!eregi('^([0-9a-zA-Z\_\.-\$]+)$', $host))
    Version 1.1.4:
    if (!eregi('^([0-9a-zA-Z\_\.-]+)$', $host))
    I remodified the code in 1.1.5 and it seems to be working again with dashes. Hopefully I did not break anything else.
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Sorry for this problem. Correct fix is:
      if (!eregi('^([0-9a-zA-Z\_\.\$-]+)$', $host))
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • Palmertree
        • Sep 2005
        • 746
        Thanks Alex for the quick reply. I will make the adjustments.
        • aelix
          • Jan 2007
          Same problem with expressions too
          I applied this patch, but I still get "expression does not match" errors for all my hosts that have dashes in their hostname! This happens if I update a trigger, for example.
          • James Wells
            • Jun 2005
            • 664
            Greetings,
            Please see BUG: Arithmetic Minus Not Supported In Triggers to see how to fix that one.
            Unofficial Zabbix Developer
            • aelix
              • Jan 2007
              Originally posted by James Wells
              Greetings,
              Although I probably would have hit that bug eventually, I found my problem is in config.inc.php line 683:
              if (eregi('^\{([0-9a-zA-Z\_\.-\$]+)\: ......
              should be
              if (eregi('^\{([0-9a-zA-Z\_\.\$-]+)\: .....
              • nevzorofff
                • Oct 2008
                • 26
                Why dosn't allowed to use national characters in hostname(not in DNS)?
                Russian trigger i can set, but hostname - can't.
                • micw
                  • Oct 2008
                  Same issue here in version 1.6.1: It's not possible to add hostnames with dashes. This should be filed as bug because the hostname field must accept any character that is allowed for hostnames.
