Zabbix Proxy crash while connecting to hosts
  • Future_CG
    • Nov 2017
    Hi
    I have a Zabbix Server (v 3.2.7) which connects to a zabbix proxy (v 3.2.3) installed on pfsense (v 2.3.4).
    Problem: Proxy crashes after connection to hosts with following error:
    Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x3530312d]. Crashing ...
    62565:20171107:111657.196 ====== Fatal information: ======
    62565:20171107:111657.196 program counter not available for this architecture
    62565:20171107:111657.196 === Registers: ===
    62565:20171107:111657.196 register dump not available for this architecture
    62565:20171107:111657.196 === Backtrace: ===
    62565:20171107:111657.197 === Memory map: ===
    62565:20171107:111657.197 memory map not available for this platform
    62565:20171107:111657.197 ================================
    61260:20171107:111657.198 One child process died (PID:62565,exitcode/signal:1). Exiting ...
    61260:20171107:111659.225 syncing history data...
    61260:20171107:111659.231 syncing history data done
    61260:20171107:111659.233 Zabbix Proxy stopped. Zabbix 3.2.3 (revision 64610).
    We had before Proxy version 2.2 which worked fine until last thursday.
    Attached Proxy config file
    Thanks for your help
  • Future_CG
    • Nov 2017
    Problem Zabbix Proxy crashing
    Hi
    My Zabbix Proxy v. 3.2.3 on pfsense v. 3.2.4 is crashing as soon as he connects with hosts. Error Message is attached aswell as proxy config.
    Zabbix Server is version 3.2.7
    thanks for the help.
    • LenR
      • Sep 2009
      • 1011
      Did you drop and recreate the proxy database when you upgraded? If you didn't, try that.
      Your proxy and server should be the same version, but I don't know if they are far enough apart to be a problem.
      • Future_CG
        • Nov 2017
        Hi
        No as I uninstalled the proxy version 2.2 and installed 3.2 newly
        I then recreated the database.
