Upgrade from 3.2.6 to 3.2.9 problem
  • Rodney
    • Jun 2008
    • 15
    I´m trying to upgrade Zabbix Server from 3.2.6 to 3.2.9 but I´m having problem when Zabbix starts the database patch to clean up the problem table.
    My problem table is huge with more than 12 millions registers and I think that this is the cause, as Zabbix is not able to clean up the table and stops with this message:
    [Z3005] query failed: [2014] Commands out of sync; you can't run this command now [rollback;]
    Can anyone help me?
    Thanks in advance.
  • kaspars.mednis
    • Oct 2017
    • 349
    Hello Rodney,
    I may try to help you.
    12 mil rows is large, but not so huge table, it must upgrade without problems.
    If this is still an unresolved issue - are there any errors in mysql.log file ?
    Regards,
    Kaspars
