zabbix site is loading too slow
  • trivi
    • Nov 2017
    I am using zabbix 3.0.7 version with mysql DB. When i am fetching previous data through the web UI, the site is loading for hours.
    Please help me in resolving this. It will be very appreciated.
  • kaspars.mednis
    • Oct 2017
    • 349
    Hello !
    You can use the zabbix frontend debug tool to find the "killer" query
    And i suggest to look at MySQL DB side, because almost all data for zabbix frontend is gathered from there.
    How large is the DB size?
    How much RAM has the DB server ?
    How large is your innodb_buffer_pool_size in my.cnf?
    Regards,
    Kaspars
    • trivi
      • Nov 2017
      Originally posted by kaspars.mednis
      Hello !
      Regards,
      Kaspars
      Hi
      Thanks for the response.
      DB used only 25%.
      16GB of RAM allocated.
      i didnt find parameters of innodb in my.cnf..
      Could you please help me in this. I am using centos7.
      • allexpetrov
        • May 2017
        • 361
        Please check the Apache error logs. Can you spot any errors there?
        Regards,
        Alex!
        • trivi
          • Nov 2017
          Hi
          Didn't find any errors with httpd.
          Able to get the httpd but unable to fetch the previous data of resources.
