Hi there.
I'm using Debian 9, Zabbix 3.4.3. I've a custom alert script that is sending me some details when specific problem occurs. Anyway, I've noticed some differences between how resolved events are handled.
So, for example, if I set trigger to generate MULTIPLE events - this will indeed create MULTIPLE events in e.g. zabbix 3.4.3 and you will see multiple events on the dashboard. Now, for example in old zabbix, 2.4. when this setting was checked under trigger, there was only ONE event created under dashboard, but sure even every X seconds trigger was executed. This is ok situation for handling multiple events, because I want to receive multiple alerts when something is not working, however when problem is resolved, then I also get multiple resolved messages, which is not what I want.
Example if multiple events is checked:
zabbix - 2.4. - 1 event on dashboard - 100 event problem sent - 1 message with status OK
zabbix 3.4.3 - 100 events on dashboard - 100 - event problem sent - 100 messages with status OK
Is there any way to prevent this from happening? How do I sent only one OK status/message with event is resolved?
