Zabbix frontend out of date? (another "frontend does not match Zabbix database")
  • dampersand
    • Apr 2016
    • 16
    As if this we didn't have enough upgrade horror stories...
    I'm pushing the upgrade from 3.2 to 3.4 right now, and upon completing the upgrade (zabbix-server reported the database 100% upgraded and started polling, according to the log) I'm running into the following error on the web frontend:
    Database error
    The frontend does not match Zabbix database. Current database version (mandatory/optional): 3040000/3040005. Required mandatory version: 3020000. Contact your system administrator.
    Yup! Seen those before, haven'tcha?
    I think what's really freaking me out is that this shows that the frontend is actually the thing that's too old.
    I'm on a centOS7 machine being virtualized within openVZ. zabbix was installed from packages, and upgraded using the method at https://www.zabbix.com/documentation...es/rhel_centos (with the difference that I'm actually using zabbix-release-3.4-2 instead of 3.4-1).
    some outputs:
    [root@zabbix yum.repos.d]# rpm -qa | grep zabbix
    zabbix-release-3.4-2.el7.noarch
    zabbix-agent-3.4.4-2.el7.x86_64
    zabbix-server-mysql-3.4.4-2.el7.x86_64
    zabbix-web-3.4.4-2.el7.noarch
    zabbix-web-mysql-3.4.4-2.el7.noarch
      8661:20171109:152435.810 Starting Zabbix Server. Zabbix 3.4.4 (revision 74338).
      8661:20171109:152435.810 ****** Enabled features ******
      8661:20171109:152435.810 SNMP monitoring:           YES
      8661:20171109:152435.810 IPMI monitoring:           YES
      8661:20171109:152435.810 Web monitoring:            YES
      8661:20171109:152435.810 VMware monitoring:         YES
      8661:20171109:152435.810 SMTP authentication:       YES
      8661:20171109:152435.810 Jabber notifications:      YES
      8661:20171109:152435.810 Ez Texting notifications:  YES
      8661:20171109:152435.811 ODBC:                      YES
      8661:20171109:152435.811 SSH2 support:              YES
      8661:20171109:152435.811 IPv6 support:              YES
      8661:20171109:152435.811 TLS support:               YES
      8661:20171109:152435.811 ******************************
      8661:20171109:152435.811 using configuration file: /etc/zabbix/zabbix_server.conf
      8661:20171109:152435.816 current database version (mandatory/optional): 03040000/03040005
      8661:20171109:152435.816 required mandatory version: 03040000
      8661:20171109:152436.931 server #0 started [main process]
      8663:20171109:152436.932 server #1 started [configuration syncer #1]
      8664:20171109:152436.933 server #2 started [alerter #1]
      8665:20171109:152436.933 server #3 started [alerter #2]
      8666:20171109:152436.934 server #4 started [alerter #3]
      8667:20171109:152436.934 server #5 started [housekeeper #1]
      8668:20171109:152436.935 server #6 started [timer #1]
      8669:20171109:152436.935 server #7 started [http poller #1]
      8670:20171109:152436.936 server #8 started [discoverer #1]
      8671:20171109:152436.936 server #9 started [history syncer #1]
      8672:20171109:152436.937 server #10 started [history syncer #2]
      8673:20171109:152436.937 server #11 started [history syncer #3]
      8674:20171109:152436.938 server #12 started [history syncer #4]
      8675:20171109:152436.939 server #13 started [history syncer #5]
      8676:20171109:152436.939 server #14 started [history syncer #6]
      8677:20171109:152436.939 server #15 started [history syncer #7]
      8679:20171109:152436.940 server #16 started [history syncer #8]
      8681:20171109:152436.941 server #17 started [history syncer #9]
      8683:20171109:152436.941 server #18 started [history syncer #10]
      8685:20171109:152436.942 server #19 started [history syncer #11]
      8687:20171109:152436.942 server #20 started [history syncer #12]
      8689:20171109:152436.943 server #21 started [history syncer #13]
      8691:20171109:152436.943 server #22 started [history syncer #14]
      8693:20171109:152436.944 server #23 started [history syncer #15]
      8695:20171109:152436.944 server #24 started [history syncer #16]
      8697:20171109:152436.945 server #25 started [history syncer #17]
      8699:20171109:152436.945 server #26 started [history syncer #18]
      8701:20171109:152436.946 server #27 started [history syncer #19]
      8703:20171109:152436.946 server #28 started [history syncer #20]
      8705:20171109:152436.947 server #29 started [escalator #1]
      8706:20171109:152436.947 server #30 started [proxy poller #1]
      8707:20171109:152436.948 server #31 started [self-monitoring #1]
      8708:20171109:152436.948 server #32 started [task manager #1]
      8710:20171109:152436.949 server #33 started [poller #1]
      8711:20171109:152436.949 server #34 started [poller #2]
      8712:20171109:152436.950 server #35 started [poller #3]
      8713:20171109:152436.951 server #36 started [poller #4]
      8715:20171109:152436.951 server #37 started [poller #5]
      8717:20171109:152436.952 server #38 started [poller #6]
      8718:20171109:152436.953 server #39 started [poller #7]
      8719:20171109:152436.953 server #40 started [poller #8]
      8720:20171109:152436.954 server #41 started [poller #9]
      8721:20171109:152436.955 server #42 started [poller #10]
      8722:20171109:152436.955 server #43 started [poller #11]
      8723:20171109:152436.956 server #44 started [poller #12]
      8724:20171109:152436.956 server #45 started [poller #13]
      8725:20171109:152436.957 server #46 started [poller #14]
      8729:20171109:152436.967 server #50 started [poller #18]
      8727:20171109:152436.969 server #48 started [poller #16]
      8739:20171109:152436.971 server #60 started [poller #28]
      8730:20171109:152436.971 server #51 started [poller #19]
      8731:20171109:152436.972 server #52 started [poller #20]
      8726:20171109:152436.973 server #47 started [poller #15]
      8733:20171109:152436.973 server #54 started [poller #22]
      8728:20171109:152436.974 server #49 started [poller #17]
      8734:20171109:152436.974 server #55 started [poller #23]
      8741:20171109:152436.975 server #62 started [poller #30]
      8736:20171109:152436.975 server #57 started [poller #25]
      8737:20171109:152436.976 server #58 started [poller #26]
      8738:20171109:152436.977 server #59 started [poller #27]
      8732:20171109:152436.977 server #53 started [poller #21]
      8740:20171109:152436.978 server #61 started [poller #29]
      8735:20171109:152436.979 server #56 started [poller #24]
      8742:20171109:152436.987 server #63 started [poller #31]
      8748:20171109:152436.989 server #68 started [poller #36]
      8746:20171109:152436.991 server #66 started [poller #34]
      8751:20171109:152436.991 server #71 started [poller #39]
      8753:20171109:152436.997 server #73 started [poller #41]
      8747:20171109:152436.997 server #67 started [poller #35]
      8754:20171109:152437.004 server #74 started [poller #42]
      8745:20171109:152437.009 server #65 started [poller #33]
      8755:20171109:152437.009 server #75 started [poller #43]
      8757:20171109:152437.009 server #77 started [poller #45]
      8760:20171109:152437.010 server #80 started [poller #48]
      8749:20171109:152437.010 server #69 started [poller #37]
      8759:20171109:152437.010 server #79 started [poller #47]
      8750:20171109:152437.010 server #70 started [poller #38]
      8756:20171109:152437.010 server #76 started [poller #44]
      8752:20171109:152437.010 server #72 started [poller #40]
      8758:20171109:152437.011 server #78 started [poller #46]
      8744:20171109:152437.015 server #64 started [poller #32]
      8763:20171109:152437.021 server #83 started [poller #51]
      8761:20171109:152437.021 server #81 started [poller #49]
      8767:20171109:152437.025 server #87 started [poller #55]
      8765:20171109:152437.025 server #85 started [poller #53]
      8766:20171109:152437.026 server #86 started [poller #54]
      8762:20171109:152437.027 server #82 started [poller #50]
      8771:20171109:152437.028 server #91 started [poller #59]
      8764:20171109:152437.030 server #84 started [poller #52]
      8770:20171109:152437.033 server #90 started [poller #58]
      8773:20171109:152437.036 server #93 started [unreachable poller #1]
      8772:20171109:152437.038 server #92 started [poller #60]
      8768:20171109:152437.040 server #88 started [poller #56]
      8774:20171109:152437.045 server #94 started [unreachable poller #2]
      8769:20171109:152437.045 server #89 started [poller #57]
      8787:20171109:152437.050 server #101 started [trapper #5]
      8776:20171109:152437.052 server #95 started [unreachable poller #3]
      8778:20171109:152437.055 server #96 started [unreachable poller #4]
      8784:20171109:152437.057 server #99 started [trapper #3]
      8782:20171109:152437.061 server #98 started [trapper #2]
      8785:20171109:152437.063 server #100 started [trapper #4]
      8781:20171109:152437.066 server #97 started [trapper #1]
      8789:20171109:152437.070 server #102 started [icmp pinger #1]
      8791:20171109:152437.071 server #104 started [icmp pinger #3]
      8790:20171109:152437.074 server #103 started [icmp pinger #2]
      8792:20171109:152437.077 server #105 started [icmp pinger #4]
      8793:20171109:152437.081 server #106 started [icmp pinger #5]
      8795:20171109:152437.081 server #107 started [icmp pinger #6]
      8803:20171109:152437.090 server #109 started [icmp pinger #8]
      8804:20171109:152437.095 server #110 started [alert manager #1]
      8801:20171109:152437.100 server #108 started [icmp pinger #7]
      8805:20171109:152437.100 server #111 started [preprocessing manager #1]
      8818:20171109:152438.004 server #114 started [preprocessing worker #3]
      8817:20171109:152438.015 server #113 started [preprocessing worker #2]
      8807:20171109:152438.099 server #112 started [preprocessing worker #1]
    <?php
    // Zabbix GUI configuration file.
    global $DB;
    $DB['TYPE']     = 'MYSQL';
    $DB['SERVER']   = 'localhost';
    $DB['PORT']     = '0';
    $DB['DATABASE'] = 'zabbix';
    $DB['USER']     = 'zabbix';
    $DB['PASSWORD'] = '<redacted>';
    // Schema name. Used for IBM DB2 and PostgreSQL.
    $DB['SCHEMA'] = '';
    $ZBX_SERVER	 = 'localhost';
    $ZBX_SERVER_PORT = '10051';
    $ZBX_SERVER_NAME = 'Zabbix';
    $IMAGE_FORMAT_DEFAULT = IMAGE_FORMAT_PNG;
    How in the devil do I get the web frontend to the right version? I've uninstalled and reinstalled zabbix-web, but all that's done is make me grouchy. Anyone have ideas?
  • dampersand
    • Apr 2016
    • 16
    So, for those reading in the future, I came up with a workaround immediately after posting, but... it seems like there's a bigger problem somewhere.
    in /var/www/html/zabbix/include is the file 'defines.inc.php', that defines a crapton of php variables (including the following):
    define('ZABBIX_VERSION',        '3.4.4');
    define('ZABBIX_API_VERSION',    '3.4.4');
    define('ZABBIX_EXPORT_VERSION', '3.4');
    define('ZABBIX_DB_VERSION',     3040000);
    These lines were all set to 3.2 numbers (ie, 3020000).
    I'm not sure why the upgrade to the correct zabbix-web didn't fix these (which means Something Is Not Right), and I'm a little scared about it, but the workaround is in place and I can access my toys.
    If anyone has any ideas as to the cause, please lemme know.
    • dampersand
      • Apr 2016
      • 16
      Yup. Went to investigate a little farther.
      The php frontend source of zabbix-3.4.4 differs tremendously from the stuff in the packages. No idea what happened here, but my workaround-ed 'charts.php' is throwing an error in the web console.
      thankfully, installing the frontend from sources is actually really easy - according to the zabbix material, all one does is move crap from the zabbix-3.4.4/frontend/php/ directory to the /var/www/html/zabbix/ directory (reserving old conf files, etc). Hopefully that helps someone in the future.
      Nonetheless, I'd LOVE to know why updating zabbix-web doesn't actually update zabbix-web. Not looking forward to the next upgrade (when I'll have completely forgotten all that I've done for this one). Bonus points for any tips.
      • allexpetrov
        • May 2017
        • 361
        Hi there,
        Which command you've issued to upgrade the packages?
        Regards,
        Alex!
        • dampersand
          • Apr 2016
          • 16
          oh, y'know, the usual...
          #copy all the config files and stop all the services
          yum clean all
          yum upgrade
          yum upgrade zabbix-web
          yum upgrade zabbix-*
          #wtf is going on why isn't this working
          rm /etc/yum.repos.d/zabbix
          rpm -Uvh http://repo.zabbix.com/zabbix/3.4/rhel/7/x86_64/zabbix-release-3.4-2.el7.centos.noarch.rpm
          yum update
          #maybe it's being served from another repository?
          yum clean all
          yum update
          yum search zabbix
          #nope, no zabbix without the zabbix repo
          #etc, etc, etc
          etc etc etc... just a lot of trying every command I know of! There's way more in there, but who can remember what they did five days ago? I sure can't xD
          • kaspars.mednis
            • Oct 2017
            • 349
            You tried
            Zabbix 3.4.4 is without -centos
            http://repo.zabbix.com/zabbix/3.4/rhel/7/x86_64/zabbix-release-3.4-2.el7.noarch.rpm
            you can look at http://repo.zabbix.com/zabbix/3.4/rhel/7/x86_64/
            Regards,
            Kaspars
            • allexpetrov
              • May 2017
              • 361
              To avoid any misunderstanding and misconfiguration - please visit this page: https://www.zabbix.com/documentation...es/rhel_centos
              Use history command
              Regards,
              Alex!
