Configure 3.4.4 for Fedora27
  • Durwin
    • Apr 2015
    • 19
    I have version 3.4.4 and am getting this error.
    checking for the linux kernel version... unknown family (4.13.12-300.fc27.x86_64)
    checking size of void *... 8
    checking for mysql_config... /usr/bin/mysql_config
    checking for main in -l... no
    configure: error: Not found mysqlclient library
    I was successful configuring 3.4 for Fedora26, but I cannot configure 3.4.4 for Fedora27. Anyone have any suggestions?
    Thank you,
    Durwin
  • Durwin
    • Apr 2015
    • 19
    The locate command showed the following.
    $ locate libmysqlclient
    /usr/lib64/mysql/libmysqlclient.so
    /usr/lib64/mysql/libmysqlclient.so.18
    /usr/lib64/mysql/libmysqlclient.so.18.0.0
    /usr/lib64/mysql/libmysqlclient_r.so
    The command used.
      $ ./configure --enable-server --enable-agent --with-mysql=/usr/lib64/mysql/libmysqlclient.so --enable-ipv6 --with-net-snmp --with-libcurl --with-libxml2
    The config.log show this.
    configure:8058: checking for mysql_config
    configure:8088: result: /usr/lib64/mysql/libmysqlclient.so
    configure:8183: checking for main in -l
    configure:8202: gcc -o conftest -g -O2   -rdynamic   conftest.c -l  -lm -ldl  -lresolv  >&5
    /usr/bin/ld: cannot find -l-lm
    collect2: error: ld returned 1 exit status
    configure:8202: $? = 1
    configure: failed program was:
    | /* confdefs.h */
    You can see where it says, 'cannot find -l-lm'. Why is it looking for '-l-lm'?
    And this.
    | int
    | main ()
    | return main ();
    |   return 0;
    configure:8212: result: no
    configure:8220: error: Not found mysqlclient library
    ## Cache variables. ##
    ac_cv_build=x86_64-pc-linux-gnu
    I did find this which authenticates the problem, but no fix. https://lists.fedoraproject.org/arch...2MYFMJMYUK3WP/
    • volter
      • Dec 2011
      • 85
      See https://support.zabbix.com/browse/ZBX-12232
      • Durwin
        • Apr 2015
        • 19
        Thank you for the reply.
        I applied the patch fix-m4-mariadb-search.patch to 3.4.4 (the other looks to be for 3.0). However, I still receive the same error. Does fix-m4-mariadb-search.patch only work for 3.4.0 as shown at the top of the file?
        Regards,
        Durwin
